2000 Explorer Sport, Check Engine Light... - Ford Truck Enthusiasts Forums
Old 03-15-2009, 12:18 AM
Ed Ed is offline
Ed is gaining momentum as a positive member of FTE.
Talking 2000 Explorer Sport, Check Engine Light...
About two weeks ago, my 2000 Explorer Sport, 4.0 V6 "Check Engine" light came on unexpectantly, without warning in the upper left hand corner of the dashboard. Of course my first thought was "what the &%$#!" as for some reason, Fords I have owned (and driven) always seem to trip the CE light at some time. 79,000 miles, original. No lack of power, engine runs smooth and normal, starts fine when cold, ect.
I figured I would have to take it in to have the code(s) read, and to find out what the problem is.
Then today, I was heading onto a freeway entrance ramp. Traffic was heavy and moving at a brisk clip. Put the pedal nearly to the floor, ran through the gears, up and up to 75 MPH and viola! "Check Engine" light turned off. I was shocked.
Never came back on, and when I went out to drive it later (cold start, about a 10 mile round trip) the light stayed off. I was giddy with delight...
Any ideas as to why this happened? Have any other Explorer or Mountaineer owners had this happen to their SUV's?
Old 03-15-2009, 05:01 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Did you maybe put some gas in it? A loose gas cap will trip the light.
Old 03-15-2009, 09:13 AM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Could have also been EGR or CO2 related. The code is still stored in the computer. Get them pulled. Most Autozones will pull them for free.
Old 03-18-2009, 06:52 AM
Ed Ed is offline
Well, when the CE light first came on I had about 1/8 of a tank (nearly empty) but the cap was tight. I have the "one click" snap cap, so I know it was on okay.
When it went off, I had about 3/4 tank of Chevron reg. unleaded (87 oct.) and have been using Chevron gasoline since.
I will keep that in mind about AutoZone, if they'll pull the codes. Thanks for the tip, marragtop. People I have mentioned this to said it is rare for a check engine light to reset unless it is manually reset. Not sure if this is true, but only what others are telling me.
I know shops make big $$ on cars now, for diagnosining the CE light. Sometimes miss the days when a good tune up will keep your car running good, without any unexpected worries.
Ed
Check engine light, no code, blank odometer and trip counter on cold start rbolanos01 Explorer, Sport Trac, Mountaineer & Aviator 9 04-13-2015 10:03 PM
4.0 EFI engine light Dave 1998 Explorer, Sport Trac, Mountaineer & Aviator 1 11-30-2011 02:50 PM
hesitation on freeway WALLEYEWARRIOR Explorer, Sport Trac, Mountaineer & Aviator 4 09-19-2007 11:49 AM
Help! 1999 Explorer Problems smittyhines Explorer, Sport Trac, Mountaineer & Aviator 9 02-02-2004 03:27 PM
'95 Explorer check engine light yflyjump Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 11 06-19-2003 10:35 AM
Tags
2000, cap, check, code, engine, explorer, ford, gas, light, on, sport, trac, url
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
