98 expedition Truck Repair - Gear shift indicator misaligned - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 03-14-2009, 06:58 PM
mountainman101 mountainman101 is offline
mountainman101 is starting off with a positive reputation.
how do i adjust it
Old 03-14-2009, 09:36 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
The shift indicator is moved by a small cable under the dash and around top of the steering column. There is a small wheel for you to turn to move the cable a little.
Old 03-18-2009, 12:19 AM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
Misaligned shift indicator
try adjusting the cable by turning the adjusting wheel. If that is not enough to get it into alignment, try pulling down on the cable until it lines up correctly.Then use a plastic cable tie to hold it down. No need to rip out the dash either ... just stand on your head and locate the cable under the steering column area.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 12:40 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 10:21 PM
Tags
1997, adjusting, cable, correct, expedition, expedtion, f150, fix, ford, gear, indicator, misaligned, repairing, shift, shifter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
