1987 BBII relay switch to fuel pump - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 03-14-2009, 07:12 PM
MessengerII's Avatar
MessengerII MessengerII is offline
MessengerII is starting off with a positive reputation.
This relay is laying on fender well, passenger side. It burned to a crisp, both parts. I am pretty sure it has to do with the fuel pump, because when I connect two of the three wires, the engine starts and runs really good and when I disconnect the wires, the engine will turn but will not start. Do not know what the third wire goes to. I do want to replace the relay, but do not know what to ask for and I do not have the old one to take with me to the parts store. Any help, please?
Old 03-14-2009, 10:48 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
It sounds like you are referring to the "fuel pump relay", though it might also be the EEC relay (though they are technically the same relay except maybe for color).
Old 03-15-2009, 12:25 PM
Tedybear Tedybear is offline
Tedybear is gaining momentum as a positive member of FTE.
One wire will be to going to the device, one wire will go to a ground, and the other wire will be going to an "Enable" signal line that turns the relay on or off.
As a general rule of course. The fuel pump relay is designed to be on at all times the engine is running, or while starting. It uses also a prime function via the computer to power on the fuel pump(s) for about 4 seconds when the key is just turned to 'on' but not start.
Reason I bring this up? You've got 3 leads. One will be "hot", one will be "Ground" and the other line will be for the switch 'on/off' You can use a test light, and a few turns of the ignition key to 'on' to locate the signal line. Any parts house should carry replacement relays, and from the sounds of it? You'll probably want to pick up a socket. (wiring diag. will prove helpful as to how to wire in the replacement).
S-
Old 03-15-2009, 03:35 PM
Thanks so much for the great info, Big help.
Old 03-15-2009, 09:21 PM
Tedy Bear, Will one of these wires be hot with ignition on or off? Hot all the time?
Old 03-15-2009, 11:04 PM
As noted, a wiring diagram will be very useful (even the one in Chiltons/Haynes is adequate). One lead is hot at all times, and a second lead should be hot KOEO/KOER.
Old 03-15-2009, 11:35 PM
Thanks, I believe I hve it clear now...
Old 03-16-2009, 01:09 PM
Quote:
Hope this is last question about the relay. I have ordered a socket and relay thru Napa. According to them, it is a 3 prong socket and relay. (I do have 3 wires)
I do know mine was green. Do you think we are on the right road?
Thanks
Old 03-16-2009, 03:55 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Heres what the factory diagrams show for the relays:
EEC relay solid yellow wire is hot key on or off
Red/light green stripe & black/light green stripe are hot with key on
Solid red is hot with key on.
Pump relay solid yellow wire is hot key on or off.
Solid red, tan/light green, orange/light blue are hot with key on.
FYI the PCM grounds the voltage on tan/light green to close the relay & turn on the fuel pumps.
Old 03-16-2009, 06:43 PM
Thanks
Don't think so. as 87XLT points out, the wiring diagram shows 4 lead to the fuel pump relay: one lead from the battery, one lead from the EEC relay, one lead going to the pump, and one lead going to the PCM/self-test connector. You might want to have NAPA check what they are getting.
FWIW, the fuel pump relay and the EEC relay are essentially the same relay (except maybe for case color). If your EEC relay and socket are still intact, you should be able to use those to compare.
1986 f150 electrical fuel pump problem dakota-boy Electrical Systems/Wiring 10 03-14-2016 10:29 AM
Fuel pump relay wiring 86Stepside 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 06-04-2015 09:31 PM
How to check if my fuel pump relay is bad? BRONC-OH 1997 - 2003 F150 2 11-21-2014 11:11 PM
Fuel Pump Not priming brandonnichols 1987 - 1996 F150 & Larger F-Series Trucks 6 12-09-2013 07:41 PM
Neighbors 2000 V10 possiable fuel pump electrical issue Monster-4 1999 to 2016 Super Duty 3 08-29-2013 10:41 PM
Tags
1987, bbii, color, eec, f150, ford, fuel, problem, pump, red, relay, socket, switch, truck, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
