Lost Ford Spare Tire Key? This Works Great!!! - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 11-14-2009, 07:52 PM
FSJ-EARL FSJ-EARL is offline
FSJ-EARL is starting off with a positive reputation.
I had the wire in my spare tire winch shred and get all mangled inside. It would not go up or down. Finally got it down, took it all apart and need to find a new wire for mine!
  #32
Old 11-14-2009, 09:26 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Here is what you have under the bed.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
  #33
Old 11-14-2009, 10:46 PM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is offline
Lubbockguy1979 has a very good reputation on FTE.Lubbockguy1979 has a very good reputation on FTE.Lubbockguy1979 has a very good reputation on FTE.
btw a 9/16 socket, a few extentions and a few solid taps with a hammer. then either use a ratchet or i use my 18v drill with a socket adapter. by far the easiest way to get the tire down and cheapest.
  #34
Old 11-15-2009, 01:09 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Quote:
Originally Posted by Lubbockguy1979 View Post
and cheapest.
It cost me nothing to pop out the offending "keyed lock".
Now,I use the jack rod just like every other vehicle does.
JL
  #35
Old 11-15-2009, 04:00 PM
slickrock01 slickrock01 is offline
slickrock01 is starting off with a positive reputation.
First thing I do is drop the spare and either put it on a rear tire carrier or coated cable it into the bed to a roof rack etc.
you've never been nut deep in mud or a river bed and got a flat I guess, or you'd get that spare out from under the truck where it will do you no good.
solid dirt roads and pavement it'd be fine under there I guess.
this was a great first post.
  #36
Old 11-15-2009, 11:06 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Do you really need a lock for the spare? Do they get ripped off a lot? That type of lock could get you in more trouble than it is worth.
  #37
Old 04-05-2010, 09:06 AM
63 Coupe 63 Coupe is online now
63 Coupe is starting off with a positive reputation.
I know this is an old thread and I stumbled on it while looking for something else. The alternative I used to replace the key may have been covered already but for what it is worth here is my story.
I discovered shortly after buying my 2002 F-250 that it did not have the key to lower the spare tire. There was only one local dealer that had a full set of keys and they were in the middle of a labour disruption. They told me to contact McGard, the manufacturer of the locks, directly. I called McGard and the people there said to take a small piece of styrofoam from a coffee cup and glue it to a piece of dowel or rod and push it into the tube and up against the lock. This gives you an impression of the lock. I then mailed it to McGard and they sent me a new key. The whole process took about a week and a half before I got the key and that was shipping it across the border to me in Canada as well. Can't remember exactly what the cost was but it was not outrageous.
Of course this does you no good if you are sitting at the side of the road and need to get the spare down in a hurry but it is another source for the key.
  #38
Old 04-05-2010, 09:32 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Quote:
Originally Posted by dkf View Post
I guess I'm the only one that drops the spare occasionally to clean out all the crap that gets flung up on the wheel, inspect the tire, fill it with air, lube the cable and even paint the wheel if it needs it.
DKF, you are the reason people steal spare tires. They are hoping to find yours!!
  #39
Old 04-05-2010, 06:32 PM
baileybones baileybones is offline
baileybones is starting off with a positive reputation.
Many thanks...I'll try that.
  #40
Old 04-05-2010, 06:34 PM
kpmalone kpmalone is offline
kpmalone is starting off with a positive reputation.
I bought my 2005 F250 a month ago and the spare tire key was not in the truck. I took it to the Ford dealership and went through their keys and dropped the tire. Went home and disassembled the tire holder and removed the key. Now I can just use the extension.. If someone wants my spare, they are gonna get it.
  #41
Old 06-06-2010, 04:56 PM
BurnGM BurnGM is offline
BurnGM is starting off with a positive reputation.
Must use a 6 point 9/16" socket, not a 12 point socket. Took 2 hours to figure that out.
  #42
Old 06-06-2010, 07:15 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
I just tried it with both and didn't have any luck. My sledge's handle is broke in half, so I'll have to dig out another one and try another day.
Are yall using chrome or impact sockets?
  #43
Old 06-06-2010, 07:54 PM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
i removed mine with the spare in place. remove the plastic tube(twist and pull), and remove the lock with a pair of pliers.
  #44
Old 06-21-2010, 01:16 AM
ak-angler's Avatar
ak-angler ak-angler is offline
ak-angler has a good reputation on FTE.ak-angler has a good reputation on FTE.
This forum is great. The '03 I just bought didn't come with a spare. So I picked one up and went to mount it under the truck. Turns out the truck didn't come with the key for the spare either. So I jumped on here and found out everything I needed to do to address the situation. 10 minutes later, I had the spare mounted under the truck. Awesome. Sure, it's not locked. But it wasn't exactly locked laying in the bed, either. And, I can just take the lock down to the local ford dealer and get a key if I ever feel the need for more security.
FTE rocks!
  #45
Old 09-17-2010, 08:39 PM
rick27 rick27 is offline
rick27 is starting off with a positive reputation.
I tried what you said. It's a CHRAFTSMAN 6 point socket. I lowered the tire and pryed out the lock. took about 10 minutes. Thank you very much
rick27
2003 f250 sc 5.4 auto od, xlt fx4 rancho rebound, 70,000 miles
Spare Tire Removal WITHOUT Key Pushdeck1 1999 to 2016 Super Duty 12 06-27-2016 07:03 PM
SKY-CREEPER. A low cost, low space alternative to a TopSide Creeper Y2KW57 1999 - 2003 7.3L Power Stroke Diesel 20 04-12-2016 08:02 AM
another superduty spare tire lock removal thread speakerfritz 1999 to 2016 Super Duty 0 11-28-2015 07:57 AM
What is up with the spare tire hoist? bigdmizer 1999 to 2016 Super Duty 21 04-19-2015 08:15 PM
Drop That Spare! JockD 1999 to 2016 Super Duty 15 12-03-2009 11:33 AM
Tags
2001, 2005, f150, f250, f350, ford, key, lower, removal, remove, socket, spare, tire, tool, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
