Need help decoding this tranny id number - Ford Truck Enthusiasts Forums
Old 03-13-2009, 11:10 PM
shephard199 shephard199 is offline
shephard199 is gaining momentum as a positive member of FTE.
It didnt have a tag but this is what I found
On CASE- RF-F2VP-7006-AC
On Tailshaft- RF-F2TP-7A040-AA
And on the bottom of the pan it said METRIC
Im tryin to find out what it came out of and what kinda tranny is it. Thanks for the help
Old 03-14-2009, 01:54 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
F2T = 1992 Truck. Should be an AOD-E.
Old 03-14-2009, 03:29 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
F2VP-7006-AC = E9AZ7005A
Application: 1989/93 Lincoln Town Car/Crown Vic/Mercury Grand Marquis/F150/250/Bronco/Econoline.
I could not find the cross reference for this Ford truck ID number: F2TP-7A040AA to the actual Ford part number.
There are three different extension housings used 1981/93 on AOD's as installed in Bronco's, F150/250's and Econolines.
One was strictly used with 4WD.
With ID numbers from 1992 (F2), and a non passenger car extension housing, you have a 1992/93 AOD from a truck, Bronco, or Econoline.
AOD = 14 Transmission Pan Bolt Holes.
Old 03-14-2009, 01:42 PM
thanks numberdummy does anyone know when ford started putting 4 intermidiate clutches in the 4r70w thanks.
Old 03-14-2009, 01:54 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Your location says Nashville TN but your state says NC on your profile ..... where ya at? I have a 2000 4R70W with 43K miles on it if you're interested. It's a short tailshaft model from a P71 (4.6L). Doesn't look like I'm going to need it anytime in the near future. PM me if interested.
Old 03-14-2009, 09:14 PM
Im from NC but go to school in Tn. Does anybody know if there is a difference in the internals of a v6 and v8 4r70w transmission.
Old 03-16-2009, 08:31 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Just the number of clutches in the forward clutch pack depending on the year of the trans.
What vehicle are you working on?
JL
Old 03-16-2009, 03:00 PM
Alright im doin a conversion of putting the 4r70w geartrain in an AOD to pick up the lower 1st and 2nd gears. I need the model with the 4 intermidiate clutches for added strength. Talking on the behalf of crown vics which are plentiful, how new do I need to go so that the tranny contains 4 clutches. I know where a 2000 and a 2001 vics are but will the older models have 4 or do these even have 4? All this is being built to go behind a 428 in my pickup. But as far as foward clutches im not using it anyway in the swap so that doesnt matter if thats the only difference in the v6 v8 models.
Old 03-16-2009, 03:09 PM
Alright im doin a conversion of putting the 4r70w geartrain in an AOD to pick up the lower 1st and 2nd gears. I the model with the 4 intermidiate clutches for added strength. Talking on the behalf of crown vics which are plentiful, how new do I need to go so that the tranny contains 4 clutches. I know where a 2000 and a 2001 vics are but will the older models have 4 or do these even have 4? All this is being built to go behind a 428 in my pickup. But as far as foward clutches im not using it anyway in the swap so that doesnt matter if thats the only difference in the v6 v8 models.
I've had apart '96-'03 models,and they all have 4 Intermediates. What you really need is a '98-up model intermediate,and reverse drum with the mechanical diode one-way clutch. The roller-type one way clutch is a sure-fail item,and was used until '98-after that they all got the mechanical diode one way clutch. One thing that may help you out a bit....Go read the following article:
TCCoA Tech Articles
Read the OD Transmissions 101 article. It's a very detailed informational reference on the 4R70W.
JL
Old 03-16-2009, 11:14 PM
Thanks Johnny that info helped alot. So u said to stick with 98 and newer thats just what i needed to know so when i go to puu-a-part this weekend ill know what model to look for. Thanks for all the help guys. This is the BEST site ever!!!!
Please help ghostdog Clutch, Transmission, Differential, Axle & Transfer Case 5 12-03-2013 08:13 PM
Transmission ID smife 1997-2006 Expedition & Navigator 6 01-07-2013 11:21 AM
Transmission ID smife Clutch, Transmission, Differential, Axle & Transfer Case 1 01-05-2013 03:21 PM
Head Casting numbers 83-351cj Modular V8 (4.6L, 5.4L) 3 12-27-2009 02:06 AM
Is this mafs??? Mechanix185E Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 02-29-2004 11:54 AM
Tags
4r70w, 7a040, cross, f2tp, f2vp7006ac, ford, grand, marquis, mercury, reference, rf, rff2tp7a040, rff2tp7a040aa, rff2vp7006ac, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
