2005 Harley Davidson 18 inch wheels? - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 03-13-2009, 07:36 PM
Paso1 Paso1 is offline
Paso1 is starting off with a positive reputation.
Will the 18 inch factory wheels off a 2005 F 250 fit on a 2001 F250 PSD Crew cab??
Thanks
Old 03-13-2009, 08:27 PM
Tylus's Avatar
Tylus Tylus is online now
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
no
F-150 = 6 lugs
F-250/350 = 8 lugs
you can probably get a wheel adapter and make them fit...but I'm fairly certain the F-150 rims aren't weight rated for a Superduty
Old 03-13-2009, 08:38 PM
I thought they were both 8 lug Both are F250. Or are you saying the Harley Davidson wheels were only on F150's
Old 03-13-2009, 09:23 PM
patrickke's Avatar
patrickke patrickke is offline
patrickke is starting off with a positive reputation.
yes they will they will fit but you may need a spacer for the proper backspacing...you should move this down to the superduty forum they will be able to tell you the exact spacers you will need...i dont think tylus realizes your asking about the superduty harley rims being put on another super duty
Old 03-13-2009, 09:24 PM
2002 F350V10 2002 F350V10 is offline
2002 F350V10 is gaining momentum as a positive member of FTE.
The 04 harley superduty 18" wheels will fit the 99-04 superdutys. However the lug nut threads changed pitch around 03-04 so when you put them on an older truck such as your 01 you need to use ford lightning lug nuts. Been there done that on my 02.
The 05 and up superdutys changed front suspension from leafs to coils, and wheel backspacing changed at the same time. Putting an 05 up superduty wheel on a 99-04 truck spaces the wheels in to far and does not work without spacers. And spacers are not the recommended solution. The solution is to simply get wheels which fit your vehicle correctly. 04 harley superduty and the newer issued ford motorsports wheel for the 99-04 are a great solution, unless you want an aftermarket wheel.
Old 03-13-2009, 10:05 PM
Great thanks for the information guys I'll get more information from the seller.
He has a great price but if they don't fit without spacers I won't take them.
Thanks again
Old 03-13-2009, 10:07 PM
patrickke's Avatar
the spacers wouldnt be too big and those wheels would look sweet
Old 03-13-2009, 11:01 PM
But if you were to use spacers, you would want hub centric spacers and not lug centric spacers. The spacers which are hub centric are quite expensive and spacers are not recommended for daily street use . Yes people do use them but I personally would not. Spacers can come loose, and wheel torque is important. Plus we are talking about trucks which can and do haul heavy loads on regular basis. On the basis of safety, I would not recommend wheel spacers for street use. If one ever failed, your wheel could come separated from the vehicle and there are a world of possibilities which could even result in serious personal injury or even death, all over a set of wheels. Just think about a side impact and I could easily see spacers breaking apart and several wheels becoming separated from the vehicle in a crash.
Old 07-25-2014, 09:59 PM
jak369 jak369 is offline
jak369 is starting off with a positive reputation.
what year lightning lugs did you use i picked up 04 harley wheels complete with original lugs for my 02 f250 and the thread on the lugs is different the lugs that came with the wheels are m14x1.5 my truck takes m14x2.0 so far the only ones i 've been able to come up with are the dorman 611-230
Old 08-31-2014, 09:33 PM
VTRZA VTRZA is offline
VTRZA is starting off with a positive reputation.
Quote:
This is excellent advice. As some who has spent ten years in the tire and wheel business I've seen a lot of very badly damaged vehicles from wheels coming off from incorrect spacers
2016 wheels on 2005 Ex? LPD Excursion - King of SUVs 6 09-24-2016 10:53 PM
Help with wheels 2005 F150 Will Bite Brakes, Steering, Suspension, Tires, & Wheels 0 03-18-2016 05:55 PM
2005 F150 and wheel backspace Will Bite 2004 - 2008 F150 0 03-18-2016 04:26 PM
What size tires? blake2182 6.0L Power Stroke Diesel 17 05-19-2011 08:30 AM
Will 2005 F-150 Wheels/Tires fit my 2003 Expy? 2000F2504X4 1997-2006 Expedition & Navigator 3 10-26-2005 01:44 PM
Tags
18, 2005, ebay, f150, ford, forsale, harley, harleydavidson, lightning, lug, nashville, rims, superduty, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
