Steering problem (wheel jerks back and forth) - Ford Truck Enthusiasts Forums
Old 03-13-2009, 08:07 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
2000 EX with the V-10 and 135k miles. This is no typical steering/wandering problem so no need to reply with posts about springs, ball joints, tie rods, etc.
The front end jerks from left to right and you can take your hands off the steering wheel and see the wheel going right, left, right, left, etc. Sometimes it is worse than others and seems be get better when it warms up. It is impossible to control and looks like you might be drunk going down the road.
I searched posts for hours with no answers so it would be appreciated if someone knows what causes it. I did see a couple posts with the same problem but they had no answers.
There is something physically pushing the wheel left and right about once every second.
It's not the U-joints either because they are both spinning freely by hand and it is in 2 wheel drive. This problem comes and goes, sometimes it acts normal and sometimes the wheel almost violently jerks back and forth. It is usually worse when it is cold.
Old 03-13-2009, 08:15 PM
DaveandJennyP DaveandJennyP is offline
DaveandJennyP is gaining momentum as a positive member of FTE.DaveandJennyP is gaining momentum as a positive member of FTE.
A friend of mine's F-250 did that. Ended up being the front u-joints were getting bound up from lack of lube in them. I have read on here a few similar stories that ended up being u-joints as well.
Old 03-13-2009, 08:16 PM
crum71's Avatar
crum71 crum71 is offline
1/8 mile Oval Track
crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.
Have you had your wheels checked? Sounds like a warped wheel or a very bad out of balance tire or something to that nature to me.
I searched posts for hours with no answers so it would be appreciated if someone knows what causes it. I did see a coulpe posts with the same problem but they had no answers.
Old 03-13-2009, 08:21 PM
Quote:
Thanks, but I don't think that's it. The U-joints just sit there when you are in 2 wheel drive and they spin freely by hand.
Old 03-13-2009, 08:27 PM
Quote:
Thanks but that's not it. The wheels have always been fine (tires good too) and it is an intermittent problem.
Old 03-13-2009, 08:33 PM
Immortal_Ben's Avatar
Immortal_Ben Immortal_Ben is offline
Mechanic by Necessity
Immortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud of
Sounds like it may be a bad steering stabilizer.
Old 03-13-2009, 08:43 PM
Quote:
But there is no force that comes from the stabilizer. This is an intermittent problem that actually pushes the wheel back and forth. I was a mechanic for 10 years so I can eliminate the obvious things but I have never seen anything like this. Thanks though.
Old 03-13-2009, 09:24 PM
I think this guy has the same problem but not as bad:
http://www.ford-trucks.com/forums/77...-steering.html
Old 03-13-2009, 09:30 PM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
Have you checked out your hub bearings?
Old 03-13-2009, 09:37 PM
newgeek's Avatar
newgeek newgeek is offline
newgeek is starting off with a positive reputation.
sounds like a similar problem i had and it turned out to be a bad belt in the tire, would have never know by just looking at it ...... but im no mechanic. good luck.
Old 03-13-2009, 10:16 PM
Quote:
They are quiet, solid, and turn smoothly. This is a force that jerks the wheel left and then right but not all the time.
Old 03-13-2009, 10:18 PM
Quote:
I might need some luck. It's not a wobble, it is a timed jerk...........very strange.
Old 03-13-2009, 10:26 PM
This is a timed jerk (about every 2 seconds) left, right left, etc, and sometimes is acts normal. It's like nothing I have ever seen in my 10 years as a mechanic.
Old 03-13-2009, 11:04 PM
97REDPSD 97REDPSD is offline
97REDPSD is starting off with a positive reputation.
Hello exv10. let see does it happen at low speeds or high speeds? When you faster does it go away?
Old 03-13-2009, 11:12 PM
Quote:
It happens at all speeds but not as bad at high speeds, and sometimes not at all.
Steering issue. Truck tryin to kill me Halfpiece 1999 to 2016 Super Duty 7 02-08-2016 04:42 PM
2003 super bad wobble/sway. Help! Brokeacehorses 1999 to 2016 Super Duty 5 12-11-2015 01:45 PM
2005 F250 steering issue 100-10x 1999 to 2016 Super Duty 4 11-21-2015 02:34 PM
Power steering problems lstr81 Escape & Escape Hybrid 3 06-23-2015 08:18 AM
steering wheel locks up Y2K1TON 1999 to 2016 Super Duty 11 12-20-2010 04:59 PM
Tags
back, big, excursion, ford, front, jerk, jerking, jerks, left, make, moves, problems, sreering, steering, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
