Starter Engaging w/o Key
Does the solenoid have a small guage wire going to a small post? That wire is the wire that engages the solenoid. If you don't have that wire, it may be ran down to the starter from the factory. You may need to pull that wire up and connect it to the top small post of the solenoid. If you already have a small wire to the small top post, then use a test light or VOM to verify you are getting the 12V to engage the solenoid when you turn the key to start the engine. I just did a search on advanceauto.com and you can get on for approx. $25.
I have that wire on the solenoid haven't really checked to see if it has power running thru it tho.. So if I'm getting power thru the small wire that engages the solenoid then what could be the other issue.. And if I'm not getting power thru it then what could it be on that end....
If I'm getting power to the solenoid then the solenoid is bad that's my guess and if I'm not getting power to the solenoid than the ignition switch is bad.. Would this be a good assumation...
Do a quick test of the solenoid. Jump between the battery power post and the small post on the solenoid. If it cranks the starter, the solenoid is fine.
Next, as said above, test for power at the small wire on the solenoid small post, while turning the ignition switch.
If no, at the transmission, check the White/Pink wire on the shifter switch for power while turning ignition switch.
If is a manual trans, check the switch on the clutch rod under the dash. There is 2 Red/Light Blue wires at the switch. One should show power while turning ignition.
Last point to check is the ignition switch. Disconnect the plug and put a jumper between the Red/Light Blue and one of the large yellow wires. That will send power directly to the solenoid and start cranking the starter.
bl1989
07-07-2016 03:02 AM
jzimm
02-17-2005 08:42 AM
