Magnesol Drywash Plans - Ford Truck Enthusiasts Forums
Old 03-13-2009, 12:39 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Does anyone have plans for a Magnesol Drywash system that they wish to share? We filter the oil going into the processor to 200 microns and process batches of 33-35 gallons @ a time. We then pump into a 60 gallon cone bottom tank with 3/4 inch drain. I see reuseable filter socks on e-bay, just would like to know how others set the filtering system up. thanks.
Magnesol Filtering & heat? ttttmaxx Bio-diesel, Propane & Alternative Diesel Engine Fuels 0 03-07-2011 01:52 PM
Better Filtering system needed Rushmore X Bio-diesel, Propane & Alternative Diesel Engine Fuels 5 06-17-2009 07:58 PM
Bearing Wear Question Knotwild Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 08-10-2008 11:51 PM
Magnesol/Engine Wear Knotwild Bio-diesel, Propane & Alternative Diesel Engine Fuels 0 08-10-2008 11:27 PM
Magnesol willbd Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 11-28-2006 08:40 AM
Tags
bottom, cone, drain, dry, magnesol, plan, plans, tank, truck, wash
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
