Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 07-01-2009, 06:02 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Quote:
Originally Posted by Argess View Post
Nice article in HotRod. Parts list seemed to leacve out crank and rods, but it looks upwards of $25K. A high price for an engine that was never in a factory car. So anything you put it in would no longer be stock (or look stock). But I still want one!!!!!!!!!!!!
Can't find the exact parts for the FE, but a 385 series forged crank is $885 from Flatlander, and the Crower rods in the same length for a BBC, which is what it seems they used, are $1415 at Flatlander. YMMV...
As for the stub "cam" being the third cam, there are no lobes on it, so it can't really be called a "cam" now can it?
As for stock, there is not a single stock part in the engine if I'm reading the article and cover of the mag correctly.
$30k with tax, license, dealer prep, cutting and wrapping.....
  #47 (permalink)
Old 07-01-2009, 08:07 PM
MeanGene427 MeanGene427 is offline
MeanGene427 is starting off with a positive reputation.
Quote:
That's what they always called it, the "stub cam"- and since the correct term is actually "camshaft", it still qualifies.
See how far it goes once someone starts picking nits? If you don't start any nits, there won't be any nits Or if the nit fits, wear it- or where the nit hits the shan- or...
Actually, in addition to driving the oil pump, the stub cam also drives the long secondary chain to the heads
  #48 (permalink)
Old 07-01-2009, 10:48 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
So which nit was the first to be picked, the nit that was nitpicked disgorged another nit, or the nit on a horse's butt?
Am I a nitwit for talking about nits?
Dang.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #49 (permalink)
Old 07-02-2009, 01:02 AM
Ask me if I give a nit.
  #50 (permalink)
Old 07-02-2009, 09:02 AM
Argess Argess is offline
Argess is starting off with a positive reputation.
I suppose the stub-cam (or whatever) would also drive the fuel pump ecentric.
In that article, they capped both sides of the #4 cam bearing so oil would go up to the right head. So what about #3 and #5, as the stub-cam only covers #1 and #2. I am trying to visualize that without much luck.....LOL.
  #51 (permalink)
Old 07-02-2009, 09:49 AM
Barry_R Barry_R is offline
Barry_R is gaining momentum as a positive member of FTE.
Number 3 and 5 just install cam bearings with the oil hole rotated so it plugs the opening.
__________________
The builder of the highest horsepower Pump Gas FEs
Proven in the Engine Masters Challenge
2008 - 429 cubes - 675 horsepower
2007 - 430 cubes - 659 horsepower
2006 - 434 cubes - 678 horsepower
2005 - 505 cubes - 752 horsepower
All on pump gas - no power adders!
  #52 (permalink)
Old 07-02-2009, 10:31 AM
Krewat's Avatar
If you look at the pic I posted, where the fuel pump eccentric usually is, there's the gear for the overhead cam chain.
What type of fuel pump was used with the SOHC's?
__________________
  #53 (permalink)
Old 07-02-2009, 01:54 PM
The article shows a "stock fuel pump gear, with the eccentric for running the mechanical fuel pump..." They say the pumps are no longer available. I should pull out my '64 or '65 HRM with the original SOHC on the cover, red glowing manifolds and all, and check.
They note a kit is available to put a hex shaft on that gear for running an injector pump or distributor.
I skimmed the article again and did not see a reference to what fuel pump they were using for their Hilborn EFI set up.
Imagine the panic that must come over the owner of such an engine when they see a dust cloud near their car....(no aircleaners in sight...)
  #54 (permalink)
Old 07-02-2009, 03:09 PM
FFR428's Avatar
FFR428 FFR428 is online now
FFR428 is gaining momentum as a positive member of FTE. FFR428 is gaining momentum as a positive member of FTE.
Art you can see the fuel pump eccentric in the pic you posted. It's on the left side (dr side) of the engine on the idler gear. Pretty easy to see.
__________________
68 Cougar XR7 GT. 454" tunnelport in progress.
  #55 (permalink)
Old 07-02-2009, 04:12 PM
RapidRuss's Avatar
RapidRuss RapidRuss is offline
FE "Freakin Expensive"
RapidRuss has a very good reputation on FTE. RapidRuss has a very good reputation on FTE. RapidRuss has a very good reputation on FTE. RapidRuss has a very good reputation on FTE.
If I could afford one...It would have to have the Kevlar Belt to run the Cams..Dont want no stinkin chain !!
__________________
Blue Saphire 70 F250 42? in the making/Rollerized C6/4:10 Locker
With a Secret BBF/TBA sometime??
  #56 (permalink)
Old 07-02-2009, 05:01 PM
Krewat's Avatar
Quote:
Yeah, you're right. I'm blind
__________________
Tags
427 , aftermarket , bill , build , c , cammer , coon , coons , ford , head , heads , manufacturer , race , s , sohc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
