99 Super Duty 7.3 with problems Ford can't find.
Hi guys, I have a 99 Super Duty 7.3 with 74k original miles, truck looks and used to run like new. While in Myrtle Beach this winter I thought I cracked an injector cup as I was getting fuel into the coolant. The amazing part, didn't even know it until I turned on the heater and smelled raw diesel. Popped the hood and there was 1.5 gal. in the expansion tank. Having to get back to Ct. it was suggested not to make the run so I took it to a Ford dealer. Fortunately they called me on every step of the way on the diagnosic work and it came down to an internal cracked fuel rail.$5200.00 later I was back on the road, that included taking out the engine and doing front/rear main, oil pan, two new heads,pedastal seals and all other seals and gaskets needed. In 2000 I put a chip in that installed in the ECM, truck ran like a bear...didn't know they were going to update the computer, they didn't ask and I didn't tell them however it wiped the chip out. Then they had a hard time starting the truck and it hasn't run the same since.
Now here is where I need some help, when it's run cold in the morning, it takes off like the chip was still in for the first 3-4 miles, then it looses power and returns somewhat to stock after it reaches temp. Detination noise extemely loud on acceleration and at times I can accelerate with no response to the pedal then all of a sudden, "bang" it accelerates. There is a noise coming from under the hood like I'm running a "thrush" on a 57 Chevy and when it hits 1600 rpms on the de-accel., sounds like a mild " jake".(not exhaust as far as I can tell). Race the motor up and as it comes down from 1200 to idle, engine shakes like it is trying to jump out, and the fuel economy went to hell. Been to 2 different dealers, one had it for 4 days, other 2 days, no codes, no fix. Here is my thought and I'm trying to get this confirmed. Is it possible on the download they did for an update on the injection system that they damaged the ECM to cause all this intermittent problems. Any other ideas?? I would surely appreciate it.
Thanks for the reply, this truck ran like you wouldn't believe, I pull a 10k boat and a 12k 5th wheel and it would pull the hills in 6th holding 60 with no problem. All these problems came out of the dealership after the "fix" so it's hard to believe anything is failing. I believe it is coming from the re assembly of the engine and installation. I purchased a programmer to replace the one they wiped and reluctant to install with all these problems. Today I installed it and ran the codes....only one was the PO603 which I understand that is normal after the installation. Then I programmed the "tow" program and took it for a ride. It just magnified all the problems by 4. Detintation noise on acceleration extremely loud, the throaty sound under the hood, louder and the de acceleration shake even heavier. Ran it 10 miles with it skipping and stumbling here and there, shut it off and check the codes......none. If I disconnect the ICP should it stall out if good or if bad will it run better(by default). Thanks
Unplug it ,then start it ....Sounds like IPR o Ring or a leak in the HPO system ..(assuming the oil is new )....
Thanks guys for the "Welcome", appreciate it, I believe they checked out the HPO and put in whatever was needed, I remember the Mech suggesting that while it was on the ground. I ran several boats commercially for a while with Detroits and Cummins and if you couldn't fix them yourself you didn't make any money, it was simple, need fuel or air, find what it didn't have. This 444 is driving me nuts and the stealers are getting no more $$$$.
