Supercab rear door latch - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-11-2009, 11:12 PM
Larry NCKS's Avatar
Larry NCKS Larry NCKS is offline
Larry NCKS is starting off with a positive reputation.
My '08 F-350 Supercab has a loose fit at the lower door latch on the rear door on the driver's side. I don't think it was loose originally. I'm wondering if the latch itself has become dirty preventing it from latching properly or whether an adjustment needs to be made. If an adjustment, can anyone tell me the proceedure? Thanks.
Old 03-12-2009, 07:46 AM
bdavis1369 bdavis1369 is offline
bdavis1369 is starting off with a positive reputation.
My driver's door does the same thing....over any bumps it sounds like it's not latched....Drives Me Crazy. I know there was a post on her recently about this but I cant seem to find it.....someone will chime in!
Old 03-12-2009, 09:02 AM
loudford loudford is offline
loudford is starting off with a positive reputation.
my lower rear passenger door was "drive me crazy" as well, found the bottom latch wasn't engaging used some silicone and worked it a few times now good. Looks like sand & dirt get up under there on both sides, starting to get rust on both sides now...
Old 03-12-2009, 11:02 AM
GVS GVS is offline
GVS is starting off with a positive reputation.
Larry, Get back over to the "SOS" board.
Old 03-12-2009, 05:51 PM
Larry NCKS's Avatar
Quote:
Why? And which board are you talking about? And what has this got to do with my original post?
Old 03-12-2009, 06:08 PM
Larry NCKS's Avatar
Quote:
Just a followup. I got to it today to lube the latch. Although it was probably time for that, it did not fix my problem. I can hear the latch clicking into the fully closed (2nd) position when I shut the door gently, so I know that's not the problem. The striker plate is immovable, leaving the latch. Perhaps I'll try to loosen and slide it, having no real information on what the proper proceedure is. Thanks again.
Old 03-13-2009, 12:37 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Not sure about the later SDs, but on my '01, neither the latch, nor the striker is adjustable.
With my '01, I had to remove the striker, round out the holes and find another set of bolts the right length to be able to adjust it.
You COULD have weatherstripping that's collapsed, and there's a fix for that, inserting surgical rubber tubing in the weatherstripping to fatten it up again.
Old 03-14-2009, 05:54 PM
GVS GVS is offline
Larry, sorry I didn't get back to you sooner. If you haven't already you should try this: loosen the two screws securing the lower striker latch plate (about one turn each) and strike the plate inboard.The anchor plates float within the body and this will allow some adjustment.
Old 03-14-2009, 08:48 PM
Larry NCKS's Avatar
Thanks, GVS. I'd tried moving the striker plate, but tried it again. It does not move. It is bolted solidly to the frame in a fixed postion as Krewat stated. I did what he suggested and "fattened" up my weatherstrip. That helped considerably, but didn't get it all. Thanks again.
Old 03-14-2009, 11:20 PM
Grey 250s's Avatar
Grey 250s Grey 250s is offline
Grey 250s is gaining momentum as a positive member of FTE.Grey 250s is gaining momentum as a positive member of FTE.
Hey, Larry.
My 06 SC rear driver's side upper latch wouldn't catch without slamming the bejesus out of it. Dealer adjusted it for me when it was in for a routine oil change. Said it was not uncommon.
Old 03-15-2009, 12:31 PM
GVS GVS is offline
That is strange.I got a solid eighth inch adjustment out of mine.It's an 06.Maybe thats one of the differences in 06 and 08.
Old 03-16-2009, 02:32 PM
Krewat's Avatar
Very strange - I've never heard that the rear door latches on the supercab were EVER adjustable.
2011 SuperCab thinks rear door is open ! firebus 1999 to 2016 Super Duty 3 08-17-2015 07:41 AM
Drivers Barn door latch rusted out TobyM Excursion - King of SUVs 3 04-20-2014 08:09 PM
2001 F250 V10 Supercab loose door prob stewl New Member Introductions 5 03-11-2014 11:53 AM
Adjusting tailgate on 2009 Escape JohnnyThunder Escape & Escape Hybrid 2 10-04-2012 08:24 AM
Door latches are loose, how do I fix them? redbug Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-18-2010 12:52 PM
Tags
99, adjust, cab, door, doors, f250, fix, ford, latch, loose, rear, rust, super, supercab, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
