1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
OBDII fuse question
Old 03-11-2009, 09:02 PM
07FX4's Avatar
07FX4
07FX4 is offline
OBDII fuse question
2005 F350 King Ranch Dually Diesel...
I just bought the truck, and found out the power port and the cigar lighter do not work. I'll check the fuses tomorrow, but have a question about the cigar lighter fuse. The manual states that the fuse for the cigar lighter also powers the OBDII. My question is this... if the fuse is blown, how does it affect the OBDII? Do you just lose power at the OBDII port, or is the OBDII non-operational all together? What are the main functions of the OBDII anyway? I believe it is supposed to perform diagnosics on the engine. If the OBDII fuse is blown, will I still get fault indications on the instrument panel if faults occur?
Old 03-11-2009, 11:00 PM
Wash1331's Avatar
Wash1331
Wash1331 is offline
The function of the OBDII port is to link a reader to the ecm. The ecm actually performs the diagnostics on the engine. The ecm will still function with the fuse blown, but you will not be able to pull up codes and readings without the fuse operational.
Old 10-10-2010, 05:48 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
07FX4 --
Did you ever resolve the power port and the cigar lighter issue???
biz
Old 10-10-2010, 08:42 PM
jc8825's Avatar
jc8825
jc8825 is offline
I sure hope he did after a year and a half!!
Old 02-17-2012, 10:06 AM
td3excursion's Avatar
td3excursion
td3excursion is offline
Any additional feedback on this issue would be greatly appreciated! I'm having the same problem on a 2000 Diesel Ex. I would never have even checked for codes and found a non working DLC if I haven't noticed a big drop in MPG. After reading this post, I checked the cigar lighter and indeed it doesn't work. I will find the fuse and change it out today. But now wondering if at all this might effect the mpg/mpg overhead display?
Old 02-17-2012, 05:41 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
It won't. The only thing that fuse does is provide power to a pin on the DLC, so that devices plugged into it can have power. Nothing more.
All of the diagnostics, etc are handled by the engine, transmission and other computers.
Whitey Ford
20
12-14-2019 11:41 AM
CMB1998
Modular V10 (6.8l)
05-05-2014 06:49 AM
mountainsportsman
17
07-16-2013 11:22 PM
12amracer
1997-2006 Expedition & Navigator
11-17-2011 09:30 PM
Jaime74656
07-22-2011 09:20 AM
Quick Reply: OBDII fuse question
