Bluetooth connect to f250 radio - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-11-2009, 08:01 PM
kcschultz kcschultz is offline
kcschultz is starting off with a positive reputation.
I recently bought a new 2008 F250 where there is a phone symbol on the radio. I can get my phone to detect the radio but dont know how to sync the two. Any ideas how to use this feature?
Old 03-11-2009, 08:13 PM
high ho silver's Avatar
high ho silver high ho silver is offline
high ho silver is gaining momentum as a positive member of FTE.
Does it not cover it in the owners manual for the truck?
Old 03-11-2009, 08:17 PM
No, it merely mentions the phone option, just not how to connect to it.
Old 03-11-2009, 08:23 PM
Ummm. Thats odd. I do know that not all cell phones are compatible with the factory bluetooth. Just talked to a friend yesterday that had his Acura TL in for just that. He said that he could make a call through the system but could not answer one. They told him his phone was not one of the ones Acura had set up to accept. You should be able to go into the system and have it give you the option to select the phone you have and hopefully yours is listed.
Old 03-11-2009, 08:34 PM
Deluxe05's Avatar
Deluxe05 Deluxe05 is offline
Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.
Taken from page 125 of the 2008 "Navigation System Supplement (2nd Printing)":
Adding a new phone to SYNC
Note: This is a speed dependent feature. For your safety, this procedure cannot be completed if the vehicle is traveling at speeds faster than 3 mph (5 km/h).
Note: SYNC can store up to 12 previously paired phones.
This feature allows you to add (pair) a new Bluetooth enabled phone to
SYNC. To access:
  1. Press the PHONE hard button on the navigation system.
  2. Select the ‘Settings’ tab on the touchscreen.
  3. Select ‘Add’.
  4. When prompted on your phone’s display, enter the PIN provided by SYNC.
Depending on your phone’s capability, you may be prompted with additional options from your phone or SYNC such as downloading the phone book/call history and setting a favorite.
Old 03-11-2009, 08:47 PM
Thanks for the quick responses. Mine is not a sync system. On the right side of the radio over the "aux" button is one labeled "Phone". Does it set up the same way?
SYNC. To access:
  3. Select ‘Add’.
KC...now this is what you call service with a smile. I knew someone with the goods would come along a help.
Old 03-11-2009, 10:37 PM
Deluxe05's Avatar
Quote:
Gotcha...sorry, I guess I jumped the gun there.
It is my understanding that this button is reserved for use with certain aftermarket phone kits--like the Mobile-Ease Hands Free System that Ford sells. Without one of these kits, the button does nothing of value.
http://www.fordaccessoriesstore.com/...~7L2Z_19G399_A
Old 03-13-2009, 04:18 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
You say that your phone sees the radio, does it ask for a PIN when you try to connect, or does it not even connect?
SYNC issues DDaughtrey 1999 to 2016 Super Duty 4 11-14-2016 03:26 PM
Radio Message Ridge 1999 to 2016 Super Duty 2 03-30-2016 07:11 AM
"PHONE" button on radio?? todouble 6.4L Power Stroke Diesel 18 01-16-2016 09:14 PM
Connecting Cell Phone to Factory Radio bengitschier 1999 to 2016 Super Duty 10 05-30-2014 10:46 AM
6 disc radio with "phone" button johnw 1999 to 2016 Super Duty 13 08-15-2008 10:16 PM
Tags
2007, 2008, bluetooth, blutooth, connect, f250, ford, link, phone, radio, sync
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
