gas in 7.3 PSD
gas in 7.3 PSD
Loaned out my 2002 Ford 7.3 PSD to a friend who lost his job and had to sell his house and move. They thought they were doing me a favor by filling it up with 42 gallons of GAS.
They ran it approx. 7 miles before it dawned on them that it was a diesel. I had it towed and removed the gas. The dealership removed the tank, replaced the fuel pickup, sending unit, treated the tank, blew out the lines, replaced the fuel filter assy., and gravity fed the fuel rails.
The truck ran, but with reduced power and lots of blue smoke in the exhaust. Replaced the injectors. The dealership stated that the sleeves? for the injectors looked good. They don't feel that there is any other damage to the engine as it runs too well.
My problem is that the truck still has blue smoke in it on cold start ups. It didn't before. The blue smoke dissapates as the truck warms up. It doesn't seem to blow blue smoke under load. I was looking for advice as what might be the cause of it.
No fuel additives are in the diesel. I also have a second 7.3 using the same fuel and no blue smoke.
Help please.
Help please.
Guess I'm lucky that no one wants to borrow my truck, my family says it's too high and too long for them to drive
..........removed the tank, replaced the fuel pickup, sending unit, treated the tank, blew out the lines, replaced the fuel filter assy., and gravity fed the fuel rails.........Replaced the injectors. .
Help please.
Help please.
I guess the first question is, did the truck start to run bad before they pulled over, and if so how bad? Usually gas that's run too long, or too much will damage the injectors which you've already had replaced.
As others have asked, how many miles has the truck been driven since the work has been done? You will get some oil in the cylinders during an injector change, along with air in the oil rails, so it usually takes about 50 miles of driving to clear up the symptoms from an injector change.
Welcome to FTE.
Welcome to FTE.
More Info
The injectors were just replaced last week. The truck has an aftermarket exhaust, Hellwig Bars, Bilstein shocks, and in the immediate future Landyot Radius Rods.
I am also planning on converting it over to run on WVO like my other one. That is if the engine is not toast.
The smoke that comes from the exhaust is out of the norm for this truck. Prior to the event, it had less smoke (and it wasn't blue) than my other 2003 7.3.
Thanks for the info.
Additional info
It has approx. 100 miles on it since the injectors have been replaced.
Sounds like your dealer went overboard. Don't know why they would have needed to replace the pickup and sending unit. If the truck was still running alright when he stopped it, chances are good no damage was done. The blue smoke probably has something to do with the new injectors. Blue = oil. Some how oil is getting in to a cylinder or a coulpe of cylinders while engine is off.
