Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #76 (permalink)
Old 03-30-2009, 11:01 PM
70torino429's Avatar
70torino429 70torino429 is offline
Garage is empty, add now
70torino429 is starting off with a positive reputation.
ahh i see basically to pressurize the fuel to compensate for the extra air being forced in almost acting as a fuel pump sort of. i understand now. I wonder if it will make the tractor noticeably faster. ill put it all together since i have it in my garage now to make it into a 4x4 mower, lol i am very devious. i have 2 hydrostatic automatic rear axles and im mounting one up front and fabbing up a linkage to make them both work at once for full time 4x4. yes i know im crazy.
__________________
  #77 (permalink)
Old 03-30-2009, 11:06 PM
Lead Head Lead Head is offline
Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.Lead Head has a great reputation on FTE.
4WD tractor would be sweet. If you keep the governor linkage on the engine, it won't be noticeably faster, but you'll certainly have a noticeable amount of more power. You could take the governor off and let the engine rev to the moon, which would get you going fast, but then you'd risk blowing the motor
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #78 (permalink)
Old 03-30-2009, 11:11 PM
i swear ive tried everything to blow this motor and trans for the past few years to no avail lol. the governor isnt hooked up right now but i barely ever rev it high (just like to know that i can if i want to) Other than screwing around in the woods where it can get into tight places since i removed the deck and lifted 2 inches(planning on an inch or two of more lift) but other than that i use it to pull dead cars around.
__________________
  #79 (permalink)
Old 03-31-2009, 12:05 AM
460/5's Avatar
460/5 460/5 is offline
Zombie Survivalist
460/5 has a great reputation on FTE.460/5 has a great reputation on FTE.460/5 has a great reputation on FTE.460/5 has a great reputation on FTE.460/5 has a great reputation on FTE.
Quote:
Originally Posted by Ford4x4-JD70AB View Post
...so that makes you...a gay robot. sorry, couldn't resist.
lol
ANOTHER ONE!!! i feel awesome.
  #80 (permalink)
Old 03-31-2009, 12:21 AM
460/5's Avatar
Zombie Survivalist
Quote:
where do you live??? i want to to try to kill myself on this contraption. lol. sounds like alot of fun.
  #81 (permalink)
Old 03-31-2009, 08:06 AM
lol im in massachussetts. and yeah its fun lol just something i mess with when i have time to kill. i tried doing the same with an old pos john deere and well ended up with a picture window in the back of the engine block lol. ive only managed to flip this over once but it has a kind of rollbar on the back i made which keeps you somewhat safe. redoing the exhaust and the 4x4 is the next things im doing. ill have to get some pics when its all done lol
__________________
  #82 (permalink)
Old 03-31-2009, 09:28 AM
alxsnmr alxsnmr is offline
1991 Ford Bronco
alxsnmr is gaining momentum as a positive member of FTE.
I am not sure I understand how you are going to use the steering wheel on the 4x4 unless you are fabing Ujoints or some kind of knuckle in the axles. Otherwise you would have to have brake steering like that on a crawler. Now my head is getting jumbled with how you are pulling off the 4x4 part.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
  #83 (permalink)
Old 03-31-2009, 10:06 AM
i am going to have to change the steering a little bit to make it work. the toughest part is going to be the linkages for speed control as they are going to have to flex somehow. the lawntractor uses a belt driven trans and im going to try to keep it like that. im trying to find some diagrams for a few lawn tractors that were produced with a rear steer design. i may do something like that and then have the front axle welded in position. Its something ive never really seen and wanted to try. i have all the pieces or can make them so it shouldnt cost me anything really. its just a matter of getting it all together. i had a inline 4 cylinder renault engine on a lawn tractor with a shortened chrysler rear end and drum brakes with a 4 speed manual trans but i sold that to my neighbor. that one i setup to be chain driven with a huge ass chain from the back of the trans to the rear end. and was easy to "regear" it just by changing chain pulley sizes. hell it even had a car steering column that had the ignition switch and steering functional. not one of those crazy v8 mowers but the 80 or so hp that inline 4 had moved that tractor damn well lol.
__________________
  #84 (permalink)
Old 02-22-2012, 03:56 PM
breno1987's Avatar
breno1987 breno1987 is offline
1992 Ford F-150
breno1987 is starting off with a positive reputation.
Resurrecting this thread...
Unhooked and removed all of the smog crap associated with the thermactor pump and I am going to experiment tonight.
I'm using the original baffle for the smog pump that sits on the passenger wheel well and I will put a conical fram filter to fit. I then plan on running hose from the outlet of the air pump to the vacuum port on the side of the throttle body just before the throttle plates.
It will cost me nothing and I just want to try it because I'm bored haha. I'm thinking that starting with larger hose at the pump outlet and incrementally going to smaller hoses until it is finally connected to the vacuum port, will compress the air slightly further. I have a 5.0 302 speed density and will use the air pump as a supplementary intake air supply by keeping the factory intake as well.
Let's see what happens... I dunno... haha
  #85 (permalink)
Old 02-22-2012, 04:14 PM
bobbyjo9 bobbyjo9 is offline
bobbyjo9 is starting off with a positive reputation.
I gotta ask... just out of the pure curiosity of it... are you saying your going to attempt to use your factory air injection pump, to introduce "compressed" air through a vacuum port into an open plenum. Then, using the motors vacuum, introduce this charge to the combustion chamber for a performance increase?
  #86 (permalink)
Old 02-22-2012, 04:21 PM
dr1 dr1 is offline
dr1 is starting off with a positive reputation.
Feel free to google it first dude, as you can already see by the thread your not the only one to try. You'd probably have better luck (none) with the leaf blower :P
  #87 (permalink)
Old 02-22-2012, 04:30 PM
breno1987's Avatar
1992 Ford F-150
I was under the impression that the vacuum port on the throttle body of the 5.0 (originally used for the charc canister) was pre throttle plates, thus not being directly injected into the open plenum and moreso as a supplementary air supply to the factory intake.
Scratch that idea I guess haha chalk that one up to wayyyy too much thinking while on the john lol
  #88 (permalink)
Old 02-22-2012, 04:45 PM
Well it was entertaining at least... You should look up the leaf blower though.. VERY ENTERTAINING!!
  #89 (permalink)
Old 02-22-2012, 04:48 PM
breno1987's Avatar
1992 Ford F-150
Hah! Leaf blower? That's child's play... I'm going to mount a central vac system on my pickup bed and reverse the flow.
  #90 (permalink)
Old 02-22-2012, 05:21 PM
Hope you got a long cord!!
Tags
1993, 50, 58, air, cfm, chargers, emissions, f150, f250, ford, lawnmower, pump, rangers, smog, super, supercharger, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
