F350 4x4 Double U-Joint Rebuildable?
I have an 88 F350 4x4 SRW with 7.3 C6 BW 1356
The front driveshaft has the double Joint assembly at the trans case end. The joints are worn as usual, but the most slop is at the ball joint in between them, very loose. I need to take it apart, it may even be broken. If not broken, is the middle part rebuildable, or must you buy the whole driveshaft new?
Is this joint necessary, or could I replace it with a normal driveshaft of the same length? The truck has the stock springs, blocks, etc.....
Any guidance, is much appreciated!
on
1 Post
on
1 Post
My only point is that if the center support bearing is gone - there is a cylidrical socket in the center with a rolelr bearing - when it goes the cup portion of the socket physically breaks off - once it does - wobble = shot = unfixable
Ian_C
03-09-2015 09:22 PM
lastclodstanding
01-25-2012 07:32 AM
