How to remove 73-76 steering wheel
x2 on what kshaneh said.
The wheel itself takes a 15/16" socket and 1/2" ratchet and extension if
the socket's not a deep well. Yeah, it can be done with 3/8" drive stuff.
And a "steering wheel puller" and two of the same length bolts (3" to 5"
long) with 5/16-24 threads.
Just pulled the wheel on my '75 F100 parts truck and somebody used a
8mm or course threaded 5/16" bolt in the wheel's threads and screwed
them up a little. That and the headlights being screwed down without the
lugs being in their recesses are the only funny things I've found and I've
taken the whole thing apart. :)
http://www.panix.com/~alvinj/file12/pullers.jpg
The puller at the top can use two or three bolts.
The flat adapter at the bottom right, is the one to use.
Alvin in AZ
Alvin in AZ
on
1 Post
ive done that in a couple junyyards,,pull to yard and you be eating the steering wheel if it does come off
on
The following users liked this post:
Now there is a pearl of widom we can use. I need to take mine off here soon, and never gave that a thought, thanks Bro!!
Justin73supercamper
06-02-2016 10:10 PM
