Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-11-2009, 08:27 AM
n2umr n2umr is offline
Garage is empty, add now
n2umr is gaining momentum as a positive member of FTE.
Front axle leaking
I was changing my oil last week and noticed a drip of something on my front axle seal closest to the differential on the drivers side. I wiped it with my finger and smelled it and sure enough it was gear oil. Has anybody else seen this problem. It's going to the dealer tomorrow to get checked out.
Mark
2007 XLT 4x4
  #2 (permalink)
Old 03-13-2009, 10:17 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
How many miles on your rig?
A seal failure is not that uncommon.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 03-13-2009, 12:02 PM
I have 31700 miles on it. It ended up being a bad seal, fixed under warranty. I was posting to see if anyone else may have had this issue. Thanks.
Mark
  #4 (permalink)
Old 03-13-2009, 12:55 PM
berry1234's Avatar
Good thing it was under warranty.
__________________
  #5 (permalink)
Old 03-14-2009, 01:57 PM
clearnetedm clearnetedm is offline
clearnetedm is starting off with a positive reputation.
Its strange after reading this I decided to crawl under and have a peak. The front looks ok but I found a fairly large leak coming out the side of the rear diff towards the tire. Anyways it's going into the shop tomorrow.
  #6 (permalink)
Old 03-15-2009, 09:49 AM
wizardsr's Avatar
wizardsr wizardsr is offline
wizardsr is gaining momentum as a positive member of FTE.wizardsr is gaining momentum as a positive member of FTE.
Yes, it's a known issue, Ford has a TSB out on it, and any dealer worth their salt will have the seals in stock. Just had mine done at 26k on my 2007.
Check your rear shocks too, both mine were leaking at 10k. Also had to do a rear axle bearing at 8k.
  #7 (permalink)
Old 03-15-2009, 10:42 AM
Do you know the TSB info around that? It goes to the dealership tomorrow and want to make sure I have everything I need just in case.
Tags
2007, 2008, 2009, axle, diff, differential, expedition, explorer, f150, ford, front, leak, leaking, lincoln, navigator, seals, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
