i have a mid 80s 460 in front of a C6 in my 1970 F350, So i was driving down the freeway (constent speed of 60) when all of a suden it started to make a pownding noise, almost sounded like a belt split and was thumping on something. so i pull over and it made the noise untell i turned it off (i almost thought it might be a flat tire that split). so i get out and cant see anything worng with the truck. so i get it towed home so i can work on it. well i go out and check everything i can see, the dizy cant move and when i canked it (twice, without the dizy cap on) the rotor turned and everything else turned too (alt, power steering, water pump). no pullys were loose. so then i decide to see it will start and see if i can hear it and find the noise. well the starter will engage the fly wheel but will not trun the motor over. so i put a breaker bar on the crank and i could not get it to move at all. and i really tried to get it to. so now my question to all of you, what do you think it could be or how could i fine out without having to really pulling the engine apart?
any help will be great.
Quote:
Originally Posted by BradyCouchman
the engine when i first got it home would crank but now it will not, not even by hand with a breaker bar.
the other question i have is if i do need a new engine what way would you all sugest? new crate egine, long block?
Quote:
Originally Posted by bigrigfixer
Dump the oil, see what you can see in it. If you can't see anything there, you'll have to pull the pan.
i am not sure i can pull my pan without pulling the motor, but i think i will drain the oil tomorrow.
Quote:
Originally Posted by jake08
Pull each plug. Each one will tell its own tale. Good luck.
i did pull them all and nothing really looked all that off, i can take pictures of them but not sure if it would help or even if it would come out right.
i also pulled the starter and the flex plate doesnt look bad.
in the AM i will drain the oil.
Quote:
Originally Posted by orng1
Maybe a bent valve, take the valve covers off and see if anything is obviously out of place.
that is also on the list, i have a new seal for the drivers side so i will start on that side.
i can see it now i will tare down the whole engine in the truck before i find what is wrong....
Quote:
Originally Posted by Rockstone
Brady- Oil pressure, oil temp and water temp gauges were fine before this happened?
the water temp was fine, oil pressure was fine (as good as the stock gauge works), dont know the oil temp. but it didnt look/sound/smell like it was over heating when i opened the hood on the side of the freeway.
You did all that wiring, and didn't put good gauges in? tsk-tsk. lol. Like has already been said pull the valve covers and then the pan. You will probably have to raise the motor to get the pan off. good luck
ok all oil drained and both valve covers off. here is what i found:
this is the biggest thing in my oil...there was not much of it. (the blue is a glove and the little brow item felt like grim or dirt or metel shavings
As the process continues you will end up taking the timing chain cover off to see if the chain broke. You have have a busted gear or chain and a piston is up against a valve.
You could loosten all of the rockers to see if they will free up a piston. Once all of them are loose are removed, it should isolate the valve train from the equation.
If the engine turns after that, you can then remove the timing chain cover to reveal what went wrong.
i have never worked on rockers, i am sure i can get them off but not sure about getting them back on. but i am sure i can get the tiiming chain cover off and back on. along with all the other stuff, water pump, fan....)
thank you, i will let you know, but i think mine would be rebuildable (atlest get a core charge back)
Quote:
Originally Posted by Kiwi Petrol Head
Brady, Sorry to hear about your probs - It looks as if you have a coolant leak at the t/stat housing as well. I would have to agree with 75F350 - loosen of the rockers one cyl at a time and try to turn the engine over by hand. But i think that you'll find a few may be hanging up if the timing gear/chain has failed. Good luck!
Quote:
Originally Posted by 393STROKER
Dont sweat it, pull it and do a teardown
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
so the water/coolent is out (only about 3 gallons)
a 5 gallon bucket:
__________________
SoCal FTE Member
oh and the dark spots on the ground is the oil i droped yesterday
__________________
SoCal FTE Member
so we are almost sure it is a conecting rod, we could push it around but the other parts were to big to pull out.
__________________
SoCal FTE Member
__________________
SoCal FTE Member
Bummer! Well, a long block is the easiest route anyway. Just not the cheapest.
but if the rod hit much (all those bangs i heard) i will have to replace enough to pay for a $1,800 460 long block...
__________________
SoCal FTE Member
Yeah, that's what I was trying to say. If you've broken something in the bottom end, I don't think you can rebuild for the cost of a long block. Unless you just replaced one hole, and I don't think you would do that.
I hope you pull it and open the pan. I'm curious as to what all those pieces are. Can't tell much from the photos.
__________________
Folks call me Bill.
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto.'08 Diff Cover Fleetwood Pioneer,23'x5,200#
i have to, not sure a long block comes with a pan or not...but i will pull my pan off, there should be a BIG piece in there...
__________________
SoCal FTE Member
that sucks brady! i think you should forget what everyone else is saying and put a cobra helicopter jet engine in that thing , you already have a rare truck make it one of a kind with a chopper jet engine in it and itll HAUL too, towing might suck youll have to dump the exhaust out the side, not too close to the tires though, wouldnt want to melt them!
I'd say piston pieces. Something heavy is laying in the bottom of the pan.
It will be interesting to see just what all went away. One thing's for sure - the crank is locked up tighter than a bulls ass in fly season. The cam will wiggle a little bit (mucho slop in the chain) but the crank will not budge at all.
