Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 03-12-2009, 07:30 PM
orng1's Avatar
orng1 orng1 is offline
orng1 has a good reputation on FTE. orng1 has a good reputation on FTE.
LOL yeah probably huh. Didn't think about it.
I know the feeling of not having the space.
where I do my oil changes.
Don't tell anyone...
__________________
00 F250 5.4L K&N stock box folter, 257k miles.
01 F250 7.3L DP Tuner, Airaid intake, Magnaflow 4" turbo back, 88k miles. Bob
<img src="<a href=http://api.photoshop.com/home_e202e8e80efb4a1696c4980e2d094cf5/adobe-px-assets/c71a8ac8ad5f4072a1981a2a389f6f04 target=_blank>http://api.photoshop.com/home_e202e8...981a2a389f6f04</a>" width="450" height="150"/>
  #62 (permalink)
Old 03-12-2009, 08:20 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of
It'll be just our secret. But one tip - if you park closer to a storm drain, you'll have less cleanup.
__________________
Folks call me Bill.
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto.Fleetwood Pioneer,23'x5,200#
  #63 (permalink)
Old 03-12-2009, 09:28 PM
orng1's Avatar
I thought about that growing up but never did it, there is a drain about 2 cars forward.
__________________
  #64 (permalink)
Old 03-30-2009, 05:58 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE. BradyCouchman has a great reputation on FTE.
lets play name that engine part.
ok there are 3 different parts all pulled out with out taking the motor out or the oil pan off.
First and second parts:
third part:
here is a video to help you know:
and some more pictures to help:
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
Thinking the Government stimulus plan is working is like thinking that taking water form the deep end of a pool and dumping it in the shallow end will raise the water level of the pool.
SoCal FTE Member
  #65 (permalink)
Old 03-30-2009, 06:05 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
SoCal Chapter LDR
2006 Ford F-250
My Garage
SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation
Cool. Now you can disconnect the torque converter
__________________
NHRDA #4698
SoCal FTE
Join our Chapter *HERE*
9/21/54 - 9/25/09
  #66 (permalink)
Old 03-30-2009, 06:13 PM
so those heads were way to tight, it took all my effort to get one of the head bolts off, i used a breaker bar + a pipe + a socket extention and it will wouldnt come out, here is a picture to show the bending breaker bar:
__________________
SoCal FTE Member
  #67 (permalink)
Old 03-30-2009, 06:14 PM
bpounds's Avatar
2 bit Californian
Any idea what caused that? They don't just come apart for no reason. Not saying you can always tell what happened, but it sure would be nice to know.
__________________
Folks call me Bill.
  #68 (permalink)
Old 03-30-2009, 06:26 PM
have no idea, the rod is what broke the cap and bolts are still all tight, so your guess is as good as mine
__________________
SoCal FTE Member
  #69 (permalink)
Old 03-31-2009, 02:14 AM
bla1879's Avatar
bla1879 bla1879 is online now
bla1879 has a good reputation on FTE. bla1879 has a good reputation on FTE.
hmm, that sucks, at least you get a new motor, that should be sweet
__________________
- Brian -
'00 F-150 Triton 5.4L : Fabtech Lift : 16" 51 series ProComp rims : 315/75R16 Dunlop RMR :
Spintech muffler : 4.56 gears
I CORINTHIANS 10:13
So-Cal Chapter Member
  #70 (permalink)
Old 03-31-2009, 02:18 AM
orng1's Avatar
Was that a 3/8ths breaker bar you were using? I have a 1/2 or even a 1" breaker you could borrow if you still need it. I thought maybe the bolt let go. It was a little hard to tell from the angle you shot the pix.
__________________
  #71 (permalink)
Old 03-31-2009, 08:06 AM
SoCal Chapter LDR
2006 Ford F-250
My Garage
There must not be too much cylinder wear since you were able to pull the piston out the top by hand without reaming the ridge.
__________________
NHRDA #4698
SoCal FTE
9/21/54 - 9/25/09
  #72 (permalink)
Old 03-31-2009, 11:00 AM
the cylinder walls are very smoth. so i talked to a damage analist and this is what he thinks happened.
the rod had/got a crack on one side and just kinda vibraded for a bit then the other side just gave way, then the crank just beat the rod to no other. and we couldnt turn it over because the piston was into the head and the crank was up into the rod(but we were almost sure about that one anyways.
__________________
SoCal FTE Member
  #73 (permalink)
Old 04-07-2009, 10:49 PM
Bought some parts
did some painting - good from far, far from good
see next post
then about at 2:30 a truck shows up at my house
i bet i know what is in this
in the garage
yup thats a long block
__________________
SoCal FTE Member
  #74 (permalink)
Old 04-07-2009, 10:51 PM
with out the plastic
on the stand
got the old one out
whats missing??
just a little dirty
but Nicole still likes me
so that was my day...i am ready for a nap!
__________________
SoCal FTE Member
  #75 (permalink)
Old 04-07-2009, 10:54 PM
sglaine's Avatar
sglaine sglaine is offline
Crusher of B/S artist
2000 Ford F-350
sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future sglaine has a brilliant future
Brady nice Mustang in your garage and I see your making progress
__________________
00 F350 4x4 Power Stroke 6spd drw rack body 4.10
Master Slacker #12
Leader of the New Hampshire Chapter.. Come And Join - CLICK HERE
Tags
1974 , compartment , ford , glove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
