Sandblasting, just something to pass on
> What are the hazards of using glass beads compared to
>sand?
I'm not aware of any major hazards (of course you can get "clogged" by breathing inert dust of any kind), at least not compared to silica.
> I recently purchased a siphon feed blaster. Not cheapest
>but not the best. I plan to blast my frame and other body
>parts. What would you recommend I use for an abrasive? If I
>purchase a positive pressure respirator would sand the best
>choice?
Since you are probably going to be doing it outside on the ground, sand is definitely the cheap way to go WITH appropriate protection. Most abrasive media seem to run around $30 and up per 50 lb sack and that doesn't go very far if it's all being discarded after one use. You might try rigging some kind of spray booth with a plastic sheet floor, sweeping it up, sifting and reusing? Glass beads are good for mild rust and softer metals but aluminum oxide and silicon carbide are progressively more aggressive for severely rusted frames (if I remember right).
>Just remember to treat the waste as a real health
>threat.
Well said.
>sand?
>choice?
>threat.
Well said.
