Qestions about brake pads change on 2006 2wd
I am going to swap out my factory front pads on my 2006 2wd tomorrow. The ones that are on there just produce too much brake dust. I took a wheel off and had a look.
There are two 18mm bolts on the inside of the caliper. That's the caliper mounting bracket bolts and need to be left alone, right? I should be looking for two 12mm bolts to slide the caliper off for the pad swap, correct?
The 18mm and 12mm bolts will both be standard threaded left/loose and right/tight. Is that correct? There will be none of that reverse thread stuff?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
I just wanted to make sure Ford didn't have any tricks up their sleeve for me on this newer model. The last thing I wanted to do was snap a bolt head off because the thread was reversed.
Thank you.
Yes, sir. They were very simple to do. I just wanted to make sure I was looking for the right bolts and there were no tricks I needed to know.
I put a set of ceramic pads on there. So far I can't really tell a difference except that today I drove my truck around and the front wheels didn't look like someone dumped charcoal dust all over them by the time I got home.
