Replacing Water Pump - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-09-2009, 09:16 PM
Polkster's Avatar
Polkster Polkster is offline
Polkster is starting off with a positive reputation.
Replacing water pump on 2000 f450 7.3L diesel. I have pump in hand, new airtex from northern auto parts.
1) Should put new thermostat in while i'm in there? What brand and temperature range?
Heavy bucket truck hauling heavy equiptment and sits idiling long periods of time while working boom that runs off pump from engine.
2) Is there water pump replacement link somewhere on site?
Have seen repair videos on you tube before, lost that link, hopefully
someone can direct me to it.
Thanks in advance folks, the people on this site are always so helpful.
Old 03-09-2009, 09:28 PM
BlackJeep BlackJeep is offline
BlackJeep is gaining momentum as a positive member of FTE.
Diesel-Central.com the technical source for Diesel Truck information, Truck Pulling, and Drag Racing
The link above is an excellent write-up and gets quoted often, BUT, this article has some bad information about the water pump bolt torque.
It states "Tighten the water pump bolts to35-46 Lb*Ft.". THIS IS DEAD WRONG. If you do this you can easily strip the water pump mounting holes in your ENGINE BLOCK! The correct torque is 18 ft-lbs. I contacted the web site owner months ago when I discovered this problem and I was told "I've asked the author to change it". Sadly it is still wrong.
The photos and other info are very helpful. Good luck with the replacement.
Old 03-10-2009, 11:15 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I would get a new factory temp range T-stat and a billet housing from Diesel Site. That's what will be going in to my rig soon.
Old 03-10-2009, 11:23 AM
Smokin''s Avatar
Smokin' Smokin' is offline
Smokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant future
Here's a utube link. I found this particularly helpful.
YouTube - Water Pump RnR
I replaced mine with the very same airtex from Northern. I also replaced my thermostat with the 203* and went ahead and purchased the billet housing. The billet housings are nice because the ford factory stamped metal parts are pretty cheesy.
Water pump replacement on a '92 460 - a few questions SoCalAngler Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 08-10-2014 06:23 PM
Water pump for 226 flathead Marauder2004 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-30-2014 08:17 PM
1995 F250 coolant leak Breezland 1987 - 1996 F150 & Larger F-Series Trucks 3 01-15-2014 10:30 PM
(82) 4.9 water pump removal chermansr 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 11-01-2013 04:22 PM
Water Pump & Fan Clutch miihere24 1967 - 1972 F-100 & Larger F-Series Trucks 3 06-09-2013 05:51 AM
Tags
2000, 2003, 73, change, changing, diesel, f150, f250, f450, ford, installation, pump, replace, torque, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
