2004 Ford Expedition Service Engine Soon Light - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 03-09-2009, 07:56 PM
aroc126 aroc126 is offline
aroc126 is starting off with a positive reputation.
2004 Ford Expedition.
engine dies when driving slow. battery light comes on when at idel, took
truck to auto zone to test it out and they could not get a read from it, they said they had a simalar prblem with another customer, and that person said they went online and they figured out it was a fuse blown somewhere but they couldn not tell me where, does anyone have any idea where i could look, so i can get my truck diagosed, by auto zone?
Old 03-09-2009, 08:09 PM
ford12508 ford12508 is offline
ford12508 is starting off with a positive reputation.
I would say if it's a blown fuse start with the fuse box. just a hunch.
Old 03-09-2009, 08:48 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Look in your owner's manual for the fuse for the OBDII test plug. It's usually the cigar lighter fuse.
If the fuse is good, the AutoZone store needs to update their scanner to a CAN protocol unit.
Steve
Old 03-09-2009, 09:21 PM
Thanks guys, the fuse was blown, i will be taking the truck tomorrow to get it checked out! I will let you know what happens, thanks again!
Old 03-10-2009, 12:11 PM
04markIII's Avatar
04markIII 04markIII is offline
04markIII is starting off with a positive reputation.
fyi, i had a similar issue. turned out to be a 1" exposed piece of engine harness. hard to see as it was behind the intake manifold. the exposed wire was shorting out on the block, and would blow the fuse as i was driving.
Old 03-10-2009, 12:35 PM
Well I just got back from autozone and the code was P0320 which is for a crankshaft position sensor! How do i go about fixing this problem? Anyone?
Old 03-10-2009, 02:06 PM
04markIII's Avatar
lol, replace the cps! i looked at the diagram, and it's right in the front engine cover. about $50 retail at dealership. probably have to have the pcm reflashed to have the code removed afterwards.
Old 03-10-2009, 07:11 PM
Quote:
is there anyway you can shoot me over the diagram you looked at? I would greatly appreicate it!
Old 03-11-2009, 10:19 AM
04markIII's Avatar
i can if you have access to a fax.
Old 03-05-2012, 12:46 PM
Rkarma Rkarma is offline
Rkarma is starting off with a positive reputation.
Unhappy 2000 Ford Expedition, No service engine soon light coming on
I have a 2000 Ford Expedition. I took it in for the usual smog check (CA) I had an egr valve problem, got it fixed. However, it will not pass smog because... the service engine soon light does not come on. Is there a fuse that it could be or is it more than likely the bulb is burned out?
Old 03-05-2012, 06:31 PM
Since there's no fuse just for the bulb, it's likely the bulb that is burned out.
Next time, start a new thread instead of resurrecting an old, dead, and unrelated thread.
fixed the overhead readout on 2004 excursion chazman Excursion - King of SUVs 13 11-02-2012 07:06 PM
P0171 and P0174 error codes on 2004 Expedition XLT 4WD LastKahuna007 1997-2006 Expedition & Navigator 10 09-05-2011 01:42 AM
PROBLEM with battery light on dash ? snowmobile mike 1999 to 2016 Super Duty 7 04-16-2011 07:37 AM
1997 ford expedition Shift Solenoid sscapricewagon 1997-2006 Expedition & Navigator 3 02-13-2009 01:50 PM
PCV Valve -- What, Where, How Often haroutd 1999 to 2016 Super Duty 16 02-24-2003 11:59 AM
Tags
04, 2003, 2004, ac, battery, engine, expedition, expidition, ford, lamp, light, perform, reset, service, soon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
