"Clunk" when accelerating from complete stop... - Ford Truck Enthusiasts Forums
Old 03-09-2009, 03:49 PM
DRM2004 DRM2004 is offline
DRM2004 is starting off with a positive reputation.
I've been living with a mild "clunk" or "bump" in the drive train when I would first begin to accelerate from a full complete stop. It would only happen after a complete stop. It almost felt like it could be normal, but it seemed to be getting worse over time.
At first I thought it was my transmission...but after some internet searching I found some threads talking about the slip yoke on the drive shaft being the cause. In that the slip yoke needs to be pulled apart and re-lubed.
Anyway, I thought I'd post and let eveyone know that after pulling the slip yoke and re-lubing with grease my issue is solved! The "clunk" is totally gone. 100% Smooth now.
If anyone else has this issue I'd highly recommend re-lubing the slip yoke.
Ford even has a TSB out for this.
<TABLE style="BORDER-RIGHT: 2.25pt outset; BORDER-TOP: 2.25pt outset; BORDER-LEFT: 2.25pt outset; WIDTH: 96%; BORDER-BOTTOM: 2.25pt outset; mso-cellspacing: 0in; mso-padding-alt: 2.25pt 2.25pt 2.25pt 2.25pt" cellSpacing=0 cellPadding=0 width="96%" border=1><TBODY><TR><TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 2.25pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 2.25pt; BACKGROUND: white; PADDING-BOTTOM: 2.25pt; BORDER-LEFT: #ece9d8; WIDTH: 25%; PADDING-TOP: 2.25pt; BORDER-BOTTOM: #ece9d8" vAlign=top width="25%">
TSB
05-26-10<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
</TD><TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 2.25pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 2.25pt; BACKGROUND: white; PADDING-BOTTOM: 2.25pt; BORDER-LEFT: #ece9d8; WIDTH: 65%; PADDING-TOP: 2.25pt; BORDER-BOTTOM: #ece9d8" vAlign=top width="65%">
  • CLUNK OR BUMP WHEN STARTING FROM A STOP <o></o>
</TD></TR></TBODY></TABLE>
On my 2004 F-150 SuperCrew, all I needed to do was remove the drive shaft at the rear differential (4 bolts, use 12mm 12 point socket or wrench). Then remove the FRONT clamp on the slip yoke boot. Then slide out the rear 1/2 of the drive shaft. Be sure to mark the drive shaft orientation with the rear differential flange and the slip yoke before you remove the drive shaft to ensure you put it back together correctly.
Re-lube the slip yoke, then slide it back together and reinstall the four bolts at the rear differental. Torque spec is 76 ft-lbs. I used Valvoline FORD-LINCOLN-MERCURY moly grease that I purchased at my local AutoZone for $3.99. You'll also need to install a new band clamp around the rubber slip yoke boot. I got mine from AutoZone.
Here are some links I found with pictures showing how to do this. Both procedures below are on SuperDuties but its basically the same procedure. Just follow my specific details above for the 2004-2008 F-150
Slip joint regreasing
2004 F250 Slip Yoke Service
Hope this helps someone.
Old 03-09-2009, 11:08 PM
Tylus's Avatar
Tylus Tylus is online now
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
hope it stays solved...but most people report the noise comes back
the only true fix is a driveshaft replacement. oh well, a can of grease is cheaper than a driveshaft...keep us updated
Old 03-10-2009, 07:59 AM
lakeforkfisherman's Avatar
lakeforkfisherman lakeforkfisherman is offline
lakeforkfisherman is starting off with a positive reputation.
I had this problem and took it to the dealership. They said my torque converter was falling apart so they rebuilt my entire tranny. Thankfully, it was under and extended ESP warranty and only cost me $50. Good luck.
Old 03-10-2009, 11:51 AM
Oldguy4 Oldguy4 is offline
Oldguy4 is starting off with a positive reputation.
Quote:
I'll just bet that the dealership just happened to lube the slip joint while they had the driveshaft out too.
Old 03-10-2009, 12:37 PM
Probably. Hey- I got a great deal out of it.
Old 03-10-2009, 03:26 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
Why not install a grease fitting in the slip yoke so it can be lubed at regular oil change intervals? Dan.
Old 03-10-2009, 07:27 PM
mbw919's Avatar
mbw919 mbw919 is offline
mbw919 is starting off with a positive reputation.
While my '07 F-150 hasn't developed this issue, my '98 Ranger did. It's quite common with them and adding grease occasionally seems to be the long term solution.
Old 03-10-2009, 08:55 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
My 07 had this....but they did a computer flash update and it went away....
Old 03-10-2009, 10:26 PM
HoutxF150 HoutxF150 is offline
HoutxF150 is starting off with a positive reputation.
hmmm my truck only makes this noise while pulling my trailer!?!?!?! Daily driving is fine!!!
Old 05-27-2009, 10:19 PM
Just an update on my drive line "bump"....it has NOT come back. Its almost been 3 months. I'll update if it comes back.
Old 08-25-2009, 09:33 PM
Supercrewzin01's Avatar
Supercrewzin01 Supercrewzin01 is offline
Supercrewzin01 is starting off with a positive reputation.
My 2008 does the same thing, will get Ford to check it at 25,000 miles.
Old 08-30-2009, 10:49 PM
mattsautobody442's Avatar
mattsautobody442 mattsautobody442 is offline
mattsautobody442 is starting off with a positive reputation.
mine does it intermittantly when slowing down then hitting the gas...
Old 10-20-2009, 10:04 PM
jdunbar jdunbar is offline
jdunbar is starting off with a positive reputation.
TSB
05-26-10fficeffice" /><O></O>
  • CLUNK OR BUMP WHEN STARTING FROM A STOP <O></O>
Same here...had a clunk when i would stop and start. greased slip yoke and problem solved! mine was pretty sever and didnt think that would fix anything concidering there was already some grease on it, not much, but greased it anyways and put it back together. 100% gone! make sure you mark the driveline and slip yoke to make sure you get it back together so it stays aligned.
Old 10-20-2009, 10:49 PM
Roller150 Roller150 is offline
Roller150 is starting off with a positive reputation.
I have an 05 ext 4x4 5.4 and it did it when it was newer but I didnt fix anything and now its got only 50,000+ and it doesnt do it any more. It would do it only from a dead stop when I gave it a good amount of gas on take off. I guess the torque caused the drive shaft to change angle some and there you got the clunk or what ever it was/is.
Old 03-23-2010, 07:33 PM
Wildcat Fan's Avatar
Wildcat Fan Wildcat Fan is offline
Wildcat Fan is starting off with a positive reputation.
Hi. I was wondering if anyone who has an 2008 or later has been successful in getting Ford to take care of this issue? Does the TSB cover the 08 models and later?
I seem to be experiencing this issue now (in my new to me 2008 F250). I only have 12K miles on it. I called the dealer today and I was underwhelmed with the response. I was told they need to "look into this." I even mentioned the TSB from the original poster. Hmmmm....
Thanks,
Jon
TorqShift Transmission - Information and Troubleshooting bismic 6.0L Power Stroke Diesel 144 11-23-2016 07:43 AM
Acronyms bismic 6.0L Power Stroke Diesel 29 03-22-2014 10:09 PM
buying used f250; engines to avoid? elcid98 1999 to 2016 Super Duty 30 09-12-2012 09:25 AM
INFAMOUS 02 Explorer vibration........ captrivers Explorer, Sport Trac, Mountaineer & Aviator 3 05-24-2010 09:40 AM
Pic in signature wcurtis User Gallery & Picture Display 1 01-19-2008 10:12 PM
Tags
2004, accelerated, accelerating, bump, clunk, drive, drivetrain, f150, ford, pulls, stop, stopping, train, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
