"Clunk" when accelerating from complete stop...
I've been living with a mild "clunk" or "bump" in the drive train when I would first begin to accelerate from a full complete stop. It would only happen after a complete stop. It almost felt like it could be normal, but it seemed to be getting worse over time.
At first I thought it was my transmission...but after some internet searching I found some threads talking about the slip yoke on the drive shaft being the cause. In that the slip yoke needs to be pulled apart and re-lubed.
Anyway, I thought I'd post and let eveyone know that after pulling the slip yoke and re-lubing with grease my issue is solved! The "clunk" is totally gone. 100% Smooth now.
If anyone else has this issue I'd highly recommend re-lubing the slip yoke.
Ford even has a TSB out for this.
<TABLE style="BORDER-RIGHT: 2.25pt outset; BORDER-TOP: 2.25pt outset; BORDER-LEFT: 2.25pt outset; WIDTH: 96%; BORDER-BOTTOM: 2.25pt outset; mso-cellspacing: 0in; mso-padding-alt: 2.25pt 2.25pt 2.25pt 2.25pt" cellSpacing=0 cellPadding=0 width="96%" border=1><TBODY><TR><TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 2.25pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 2.25pt; BACKGROUND: white; PADDING-BOTTOM: 2.25pt; BORDER-LEFT: #ece9d8; WIDTH: 25%; PADDING-TOP: 2.25pt; BORDER-BOTTOM: #ece9d8" vAlign=top width="25%">TSB
05-26-10<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
</TD><TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 2.25pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 2.25pt; BACKGROUND: white; PADDING-BOTTOM: 2.25pt; BORDER-LEFT: #ece9d8; WIDTH: 65%; PADDING-TOP: 2.25pt; BORDER-BOTTOM: #ece9d8" vAlign=top width="65%">
On my 2004 F-150 SuperCrew, all I needed to do was remove the drive shaft at the rear differential (4 bolts, use 12mm 12 point socket or wrench). Then remove the FRONT clamp on the slip yoke boot. Then slide out the rear 1/2 of the drive shaft. Be sure to mark the drive shaft orientation with the rear differential flange and the slip yoke before you remove the drive shaft to ensure you put it back together correctly.
Re-lube the slip yoke, then slide it back together and reinstall the four bolts at the rear differental. Torque spec is 76 ft-lbs. I used Valvoline FORD-LINCOLN-MERCURY moly grease that I purchased at my local AutoZone for $3.99. You'll also need to install a new band clamp around the rubber slip yoke boot. I got mine from AutoZone.
Here are some links I found with pictures showing how to do this. Both procedures below are on SuperDuties but its basically the same procedure. Just follow my specific details above for the 2004-2008 F-150
Slip joint regreasing
2004 F250 Slip Yoke Service
Hope this helps someone.
- CLUNK OR BUMP WHEN STARTING FROM A STOP <o></o>
The following users liked this post:
I'll just bet that the dealership just happened to lube the slip joint while they had the driveshaft out too.
05-26-10fficeffice" /><O></O>
- CLUNK OR BUMP WHEN STARTING FROM A STOP <O></O>
I have an 05 ext 4x4 5.4 and it did it when it was newer but I didnt fix anything and now its got only 50,000+ and it doesnt do it any more. It would do it only from a dead stop when I gave it a good amount of gas on take off. I guess the torque caused the drive shaft to change angle some and there you got the clunk or what ever it was/is.
Hi. I was wondering if anyone who has an 2008 or later has been successful in getting Ford to take care of this issue? Does the TSB cover the 08 models and later?
I seem to be experiencing this issue now (in my new to me 2008 F250). I only have 12K miles on it. I called the dealer today and I was underwhelmed with the response. I was told they need to "look into this." I even mentioned the TSB from the original poster. Hmmmm....
Thanks,
Jon
Thanks,
Jon
