Broken nipple! - Ford Truck Enthusiasts Forums
Broken nipple!
Old 03-09-2009, 02:47 PM
KRDiesel's Avatar
KRDiesel KRDiesel is offline
KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.KRDiesel has a great reputation on FTE.
Broken nipple!
So I was working on the truck this weekend and broke the degas nipple off the radiator. Anyone have ideas on repairing this??<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 03-01-2010, 10:00 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
I just did the same thing what was your solution.
Old 03-01-2010, 10:12 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
remove radiator and take it a radiator repair shop it should run 25-50 to get a brass nipple installed.
they remove the tank from the core to repair it.
Old 03-01-2010, 10:16 PM
texans's Avatar
Ok thanks chezit. I knew you would have an answer for me. I was just reading about tapping the hole for a 1/8 barbed fitting myself. What do you think of this. Or should I just take it to a radiator shop.
Old 03-01-2010, 10:26 PM
cheezit's Avatar
they do the same thing but they should put a nut on the backside of it to hold it in place. well at least the shop that we have do ours when one of the guy gets in a hurry.
DPorter DPorter is offline
DPorter is gaining momentum as a positive member of FTE.
rad shop = guarantee no leak
Old 03-01-2010, 10:28 PM
cheezit's Avatar
Quote:
no not really just a better chance
Old 03-02-2010, 10:21 AM
DSMMH's Avatar
DSMMH DSMMH is offline
DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.DSMMH has a great reputation on FTE.
Quote:
Plastic threads are tricky. When using the tap besure to cut threads in 1/2 turns then back out and clean threads before starting again. Plastic cuts strips. Metal cuts chips. If you take your time with the threading process, you should be fine. The trick is to get long enough threads into the plastic to support physical pressure on the brass barb fitting.
I would suggest, if you do it yourself, that you do the threads, screw the brass fitting to get a good fit check and then take some JB weld made for plastic applications, coat the brass fitting threads and screw it in. The JB weld will give you a more secure fitting.
DSMMH
Old 03-02-2010, 04:31 PM
desertt5 desertt5 is offline
desertt5 is starting off with a positive reputation.
I was thinking palsti-weld. That stuff held a mirror on for years. Melsts the plastic together. maybe not though.
Old 03-02-2010, 06:29 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
I have done this literally 50+ times on a nipple on the top of the radiator of Cadillac Cts' that was bad to break and new radiator was over $1300....But the tank had plenty of "meat" to tap it, and screw in a nipple with some sealer on it (RTV is what I used) Never had one come back.
I say if the tank had enough "meat" to get some good threads, go for it.
Old 03-02-2010, 09:21 PM
DSMMH's Avatar
I agree! The reason I suggested JB weld is that it is a hard epoxy where RTV is a soft sealer. FWIW
DSMMH
Old 03-02-2010, 10:03 PM
Quote:
DSMMH
Yeah IMO either would be fine.
Old 03-03-2010, 09:31 AM
KRDiesel's Avatar
Wow, old post. I used a brass nipple and black RTV. It has held for a year now.
Old 03-03-2010, 12:22 PM
texans's Avatar
Yeah that is what I ended up doing. I did like the idea of using the jb wield though, but I already had the rtv handy so that's what I went with.
Old 03-14-2010, 12:45 PM
doityourself2009 doityourself2009 is offline
doityourself2009 is starting off with a positive reputation.
radiator removal
6.0L powerstroke
Broke nipple off radiator trying to remove the hose......Has anyone removed the radiator to take it in for repair? Are there any special tools? How hard is it to remove and reinstall? Thanks
Center console upgrade? PI360 Excursion - King of SUVs 25 05-31-2012 05:22 AM
where is the outside temp sensor? sc_mopar 1999 to 2016 Super Duty 6 03-07-2011 06:12 AM
UHAUL transport issue Jrodz 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 08-21-2009 11:46 PM
Locked Up Clutch Fan How Mpg Decreases? RÖENTGEEP 1994.5 - 1997 7.3L Power Stroke Diesel 15 12-22-2008 08:02 PM
6.0 catalytic converter crowtf 6.0L Power Stroke Diesel 16 12-20-2004 05:51 PM
Tags
barb, brass, broke, broken, cooler, delete, egr, fitting, kit, nipple, odessa, radiator, remove, screwed, tx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
