88 150 Won't Start
After cranking it over for a lil pull a plug and see if you can smell gas on it? If no gas pull the fuel line going into the intak and crank with the line in a drip pan or bucket see if you get fuel? Once your sure you have fuel its time to check spark. With the plug out and grounded crank the engine and see if you got spark its easier to get a spark tester. Spark and fuel she should run unless you have a timing issues.
