Door ajar light stays on? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 03-09-2009, 05:23 AM
Chargerkid Chargerkid is offline
Chargerkid is starting off with a positive reputation.
I have a 2001 EX. The door ajar light stays on and all the doors are shut. Even when you drive away the light still stays on for a few. This past weekend it started flickering, alarm would go off, and eventually killed the battery with the interior lights staying on. We just came home from Indiana and while driving the door ajar light would come on and off, luckily the interior lights wouldn't. Any idea what may cause this?
Old 03-09-2009, 07:55 AM
Downriver Thunder's Avatar
Downriver Thunder Downriver Thunder is offline
Downriver Thunder is starting off with a positive reputation.
If I remember right the door ajar system is triggered by the door latches. Might need to troubleshoot which one's defective. I have found usually it's the rear hatch.
Old 03-09-2009, 08:38 AM
Paul T Paul T is offline
Paul T is gaining momentum as a positive member of FTE.
I have had my rear hatch door cause a low battery because my daughter used it for leverage to stand on the bumper. Make sure it is shut. If it is shut I would start trouble shooting that latch.
Old 03-09-2009, 11:52 AM
Alfman Alfman is offline
Alfman is starting off with a positive reputation.
I have had this same problem also in the past. Over time the sensors in the latches can build up with dirt and oil. I used contact cleaner from Radio Shack and cue tips to clean out the latches and then sprayed them with WD40. This solved the problem that I had with the interior lights staying on and draining the batteries. It has been 6 months and no reappearance of this problem.
Old 03-09-2009, 12:03 PM
BigFord74 BigFord74 is offline
BigFord74 is starting off with a positive reputation.
It seem's everytime i have a door ajar situation it's 99.999% the rear hatch.
Old 03-09-2009, 02:34 PM
hvacguy's Avatar
hvacguy hvacguy is offline
hvacguy is starting off with a positive reputation.
I have had the same problem. Liberal doses of WD40 applied to the switch usually cure it. For some strange reason mine is normally the drivers door.
Old 03-10-2009, 12:39 PM
jayc3169's Avatar
jayc3169 jayc3169 is offline
jayc3169 is starting off with a positive reputation.
I had the problem a few months ago, the guys here were very helpful. My problem came from the front drivers door. I was instructed to spray it down serveral times with penetrating oil. After 5 different times of spraying the latch with oil, it finally fixed the problem. After that I sprayed ther rest of my doors and haven't had a problem since. Try that out, it may take a couple of days but it should work.
-Jay-
Old 01-07-2016, 06:54 PM
reallymattgray reallymattgray is offline
reallymattgray is starting off with a positive reputation.
Excellent advice here. Thank you! Based upon the advice here, I started working through each door, 1 by 1. I immediately knew which door it was once I lubed it, and upon closing it the interior dome light went out.
What appeared to work very well was WD-40 sprayed into the door lock's latch, opening and closing the door 5 times, and then spraying it with graphite lube to the final (lasting) lubrication.
Old 01-07-2016, 07:14 PM
Restlesswildman Restlesswildman is offline
Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.Restlesswildman has a great reputation on FTE.
Which door was it?
Old 01-07-2016, 07:43 PM
Pele's Avatar
Pele Pele is offline
Pele has a very good reputation on FTE.Pele has a very good reputation on FTE.Pele has a very good reputation on FTE.
It's weird... My doors will all cause the interior lights to come on and the chime to ding.
My hatch will not. I've left the Door Ajar light on for WEEKS without a dead battery because I've been too lazy to give the hatch a nudge.
Old 01-07-2016, 07:55 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
I experimented last week with my '05 , the door ajar light isn't on with the ignition key removed (off) even with doors open.
I already knew, after ~15 minutes of door being open, interior lights (running board too) go off. But, opening another door restarts 15 min timer. Hence, an intermittent door ajar sensor issue WILL kill the batteries.
Old 01-08-2016, 11:06 AM
Quote:
Originally Posted by Restlesswildman View Post
Which door was it?
The rear passenger side door. However, later that evening the problem came back, which tells me I need to use more lube (repeatedly, as other fellows have described in this thread).
Old 01-08-2016, 11:09 AM
I'm wondering if the black female sockets which are located at each of the vehicle's door frames, and receive the door 'nubs' when closed, play some role in this issue. These sockets have inside of them what appear to be metal clips which close in contact with one another while the door is open. They could be ground loop switches which become interrupted when the door is closed. Thoughts?
98 ford expediton ajar and interior lights stay on Ford-Muscle Expedition & Navigator 13 02-13-2016 07:09 PM
"Door Ajar" light stays on..... nagasaurus 1997 - 2003 F150 28 07-22-2013 09:58 PM
Door ajar light. Stroker 6.0 fan Expedition & Navigator 16 06-06-2013 01:51 AM
Interior lights won't shut off Natural Gas 1999 to 2016 Super Duty 10 02-15-2013 08:26 PM
door ajar rear hatch Skip1970 Excursion - King of SUVs 8 03-18-2011 04:24 AM
Tags
2003, ajar, battery, door, doorajar, draining, excursion, explorer, f150, ford, hatch, light, locations, rear, sensor, stays
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
