will egr delete screw up variable turbo
EGR activates and opens during cruising speeds to recirculate exhaust air into the intake system. because the exhaust gas cant burn twice it makes the whole engine run cooler. also if you had a delete done then you should get worse gas mileage during cruising speeds because it burns more fuel rather then recirculating exhaust gas. if you ask me... more heat can cause other components to fail in the engine or related systems.
I will agree with less mpg at cruse. With full egr delete I hope tunes will fix that. But what are you to do when every time you try to tow your camper the truck over heats and ford cant fix it. The full egr delete is the only option or maybe I should just not tow at all. I need a truck not a car.
wyatt66f100 wrote:
"the exhaust gas cant burn twice it makes the whole engine run cooler"..........................
"also if you had a delete done then you should get worse gas mileage during cruising speeds because it burns more fuel rather then recirculating exhaust gas. if you ask me... more heat can cause other components to fail in the engine or related systems."
Maybe I am dumb, this does not make sense.
I recommend leaving the EGR in place, leaving the EGR plugged in. I blocked mine at the in-take of the EGR cooler along with the up-pipe.
I have noticed that my coolant temps stay in the NORMAL range, before the EGR blocking I have almost hit the RED on my Coolant Gauge several times.
I have noticed that my Coolant fan does not run very often, only under extreme loads, before it ran loud and often under normal loads.
Mileage has increased slightly because of removing the restriction in the Turbo up-pipe blocking 50% of the right exhaust manifold.
Turbo Spools up much faster.
Turbo boost has decreased because the Turbo is not working as hard (32PSI is max)
EGT's went way down to 350 idol and 600-700 at 70 MPH with a maximum of 1200-1300 WOT, and I am tuned.
Another benefit to reducing temps is a full 4" Turbo back exhaust.
hangon2me,
I am going to do a full EGR cooler delete. I need to get rid of the POS system. I am sooooo tired of having to constantly monitor my temperature gauge HOPING it will not hit above 212* while towing. Before you say it....my truck already had headgaskets done once...they r good.
So your saying leave the EGR FUNCTIONAL AND IN PLACE?????
I thought when the EGR Cooler delete was done, it blocked exhaust flow to the EGR? Never been into one of these motors so I do not know....Can you enlighten me please?
Thanks
Thanks
