Evap Leak - Ford Truck Enthusiasts Forums
Evap Leak
Old 03-08-2009, 08:24 PM
Flareside50 Flareside50 is offline
Flareside50 is starting off with a positive reputation.
Evap Leak
Whats up guys, hey so I'm driving home today and the sevice engine soon light comes on. I check the code and its a PO4055 Evap System Large LEak. and the possible things could be either the fuel cap, vaccum leak, the canister is not working or broken or not plugged in, or the purge valve went bad. Any ideas of where to start looking and where is the canister and the purge valve located. Thanks
Old 03-09-2009, 10:06 AM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
The canister is back under the bed and near the spare tire. The purge vent valve is under the hood. Good luck!
Old 03-09-2009, 10:43 AM
Thanks well I took the negative battery terminal off and waited for a few just to see if the gas cap wasn't on tight so Ill let u guys know.
Evap purge valve location Escape? dpagates Escape & Escape Hybrid 3 11-29-2014 08:29 AM
evap system help jchoot 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-24-2014 06:21 AM
EVAP hose routing 351W manual 1989 caindog110 1987 - 1996 F150 & Larger F-Series Trucks 3 05-16-2013 07:58 PM
evap service port brookeforester Explorer, Sport Trac, Mountaineer & Aviator 0 10-24-2012 06:55 PM
Understanding the "EVAP" System LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-20-2010 04:03 PM
Tags
1997, 1999, 2003, 2004, canister, code, engine, evap, f150, ford, large, leak, located, location, po4055
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
