how do you disconnect transmission cooler lines? - Ford Truck Enthusiasts Forums
Old 03-08-2009, 06:22 PM
tmuti13 tmuti13 is offline
tmuti13 is starting off with a positive reputation.
I'm doing a tranny flush i've traced the steel lines from the passenger side of the tranny to the radiator, but am wondering how to disconnect the lines? I'm thinking its where the steel line connects to the rubber hose near the front of the truck but didn't want to assume and mess something up. Thanks in advance for your help.
Old 03-09-2009, 04:05 PM
DRM2004 DRM2004 is offline
DRM2004 is starting off with a positive reputation.
You'll want to disconnect the lines just as they go into the cooler. I wrote up a procedure on how I did this. I've done it twice now...I do this every 30k.
Search:
Auto Transmission Flush on 2004 F-150 @ 30k miles
Old 03-09-2009, 05:15 PM
DRM, I tried the search and it returned 17 pages of stuff ranging from fog lights to mp3 players and some transmission stuff, but I didn't see yours. not sure if the seach is messed up or what. Would you happen to have a link to your post? Thanks.
Old 03-09-2009, 11:14 PM
DRM, I tried the advanced search and was able to find your thread. so where is the best place to disconnect the lines to do the flush? Do you have a picture? Thanks again for your help.
Old 03-10-2009, 11:58 AM
Oldguy4 Oldguy4 is offline
Oldguy4 is starting off with a positive reputation.
[quote=DRM2004;7240331]You'll want to disconnect the lines just as they go into the cooler. I wrote up a procedure on how I did this. I've done it twice now...I do this every 30k.
Old 03-10-2009, 10:16 PM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
VFR_Man is starting off with a positive reputation.
Old 03-11-2009, 03:03 PM
thanks, VFR. I wound up only ubolting the drivers side line instead of both and it seemed to work fine.
Transmission lines upgrade? Snuggyworm 6.0L Power Stroke Diesel 42 01-29-2017 07:08 AM
how to replace rear brake line? 2003 E150 jbourne84 1968-2013 Full Size Vans 2 06-19-2016 05:07 PM
What is this for and how do you fix it? (Red hose line) Frmnsal 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 06-13-2016 08:15 AM
Replacement of rusted steel brake line?? TowsonX 1999 - 2003 7.3L Power Stroke Diesel 7 02-18-2013 03:50 AM
Fuel Line Quick Disconnect linckeil 1987 - 1996 F150 & Larger F-Series Trucks 4 09-02-2010 08:14 AM
Tags
04, 2007, 2009, cooler, coolin, cooling, disconnect, f150, ford, line, lines, removal, tool, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
