engine locked up - Ford Truck Enthusiasts Forums
engine locked up
Old 03-08-2009, 05:22 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud of
engine locked up
i have a mid 80s 460 in front of a C6 in my 1970 F350, So i was driving down the freeway (constent speed of 60) when all of a suden it started to make a pownding noise, almost sounded like a belt split and was thumping on something. so i pull over and it made the noise untell i turned it off (i almost thought it might be a flat tire that split). so i get out and cant see anything worng with the truck. so i get it towed home so i can work on it. well i go out and check everything i can see, the dizy cant move and when i canked it (twice, without the dizy cap on) the rotor turned and everything else turned too (alt, power steering, water pump). no pullys were loose. so then i decide to see it will start and see if i can hear it and find the noise. well the starter will engage the fly wheel but will not trun the motor over. so i put a breaker bar on the crank and i could not get it to move at all. and i really tried to get it to. so now my question to all of you, what do you think it could be or how could i fine out without having to really pulling the engine apart?
any help will be great.
Old 03-08-2009, 06:15 PM
the engine when i first got it home would crank but now it will not, not even by hand with a breaker bar.
the other question i have is if i do need a new engine what way would you all sugest? new crate egine, long block?
Old 03-08-2009, 07:31 PM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
Dump the oil, see what you can see in it. If you can't see anything there, you'll have to pull the pan.
Old 03-08-2009, 08:19 PM
i am not sure i can pull my pan without pulling the motor, but i think i will drain the oil tomorrow.
Old 03-08-2009, 10:28 PM
jake08's Avatar
jake08 jake08 is offline
jake08 has a good reputation on FTE.jake08 has a good reputation on FTE.jake08 has a good reputation on FTE.
Pull each plug. Each one will tell its own tale. Good luck.
Old 03-09-2009, 01:39 AM
i did pull them all and nothing really looked all that off, i can take pictures of them but not sure if it would help or even if it would come out right.
i also pulled the starter and the flex plate doesnt look bad.
in the AM i will drain the oil.
Old 03-09-2009, 01:51 AM
orng1's Avatar
orng1 orng1 is offline
orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.
Maybe a bent valve, take the valve covers off and see if anything is obviously out of place.
Old 03-09-2009, 01:55 AM
Quote:
that is also on the list, i have a new seal for the drivers side so i will start on that side.
i can see it now i will tare down the whole engine in the truck before i find what is wrong....
Old 03-09-2009, 03:06 AM
orng1's Avatar
Sorry to hear your having issues, let me know when your going to work on it. I may have time to lend a hand or at the very least hang out and keep you company.
Old 03-09-2009, 12:58 PM
Rockstone's Avatar
Rockstone Rockstone is offline
Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.
Brady- Oil pressure, oil temp and water temp gauges were fine before this happened?
Old 03-09-2009, 01:23 PM
the water temp was fine, oil pressure was fine (as good as the stock gauge works), dont know the oil temp. but it didnt look/sound/smell like it was over heating when i opened the hood on the side of the freeway.
Old 03-09-2009, 02:26 PM
Rockstone's Avatar
You did all that wiring, and didn't put good gauges in? tsk-tsk. lol. Like has already been said pull the valve covers and then the pan. You will probably have to raise the motor to get the pan off. good luck
Old 03-09-2009, 02:47 PM
ok all oil drained and both valve covers off. here is what i found:
this is the biggest thing in my oil...there was not much of it. (the blue is a glove and the little brow item felt like grim or dirt or metel shavings
i couldnt find anything wrong or that looked different then the rest of anything. to see all the different pictures go here: Ford Trucks pictures by bradycouchman - Photobucket
Old 03-09-2009, 03:14 PM
75F350's Avatar
75F350 75F350 is offline
75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all75F350 is a name known to all
As the process continues you will end up taking the timing chain cover off to see if the chain broke. You have have a busted gear or chain and a piston is up against a valve.
You could loosten all of the rockers to see if they will free up a piston. Once all of them are loose are removed, it should isolate the valve train from the equation.
If the engine turns after that, you can then remove the timing chain cover to reveal what went wrong.
Old 03-09-2009, 03:19 PM
cobraguy cobraguy is offline
cobraguy is starting off with a positive reputation.
Brady I have a rbuildable core for you in El Cajon if you end up needing one.
The Big Blue Bomb f150 302 to 351 swap Build thread BigBlueBomb 1987 - 1996 F150 & Larger F-Series Trucks 26 01-16-2016 08:58 PM
Block adapter plate moves, cracked? BruteFord Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 01-02-2014 02:02 AM
Jessicas tale, the story of a dead truck BradyCouchman 1967 - 1972 F-100 & Larger F-Series Trucks 346 10-16-2013 12:37 PM
Mystery Grinding Noise - 2006 F150 FX4 MikePDX 2004 - 2008 F150 11 12-27-2007 12:21 PM
Need help with NSS wiring bypass 75 Ford F100 wrenchhead427 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-13-2007 08:06 AM
Tags
370, 75, engine, ford, locked, start, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
