7 pin wiring harness problem
Old 06-19-2010, 03:44 PM
jstnromero's Avatar
jstnromero
jstnromero is offline
Originally Posted by beidle99
Hotrod,
I'll have to look at the parts bag next time Im at my truck and post the number for you.
Does any one know if I can install the fuse and relay now so I won't lose it even if I don't plan to tow for some time? Or will I just burn up something electronically by having it installed and not using it.
Just leave it plugged in....I leave mine plugged in all the time.
I would be scared to put it in/ take it out all the time as I might forget to do it when i needed it.
Old 06-20-2010, 05:14 AM
66fdtrucknut's Avatar
66fdtrucknut
66fdtrucknut is offline
It could be worse, my truck is missing 1 wire that is supposed to feed the brake controller, no fuse in the #17 pos. and only 1 prong, nothing to complete the circuit. My truck had a hitch, both 4 and 7 pin connector and harness in the glove box and a assurance from the salesman saying you can just plug in your controller and tow like your 05' you traded in. Took the truck back and it took them 3 hrs. to tell me I'm missing a wire, and don't know how to fix it, the last time they tried it they disabled the truck. They said they have a call into Ford technical for a fix.
robertw567
12-02-2015 12:49 PM
Trackrig
05-25-2015 09:01 PM
mjc79
18
04-26-2014 05:22 PM
secolvin
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-28-2011 04:00 PM
dogger
1999 to 2016 Super Duty
11-20-2006 11:13 AM
Quick Reply: 7 pin wiring harness problem
