2V vs. 4V heads - Ford Truck Enthusiasts Forums
2V vs. 4V heads
Old 03-08-2009, 02:20 PM
gearhed1971's Avatar
gearhed1971 gearhed1971 is offline
gearhed1971 is starting off with a positive reputation.
2V vs. 4V heads
Is there any real difference between 2V and 4V heads? I was told that it was just for numbers match ,but how do the ports match?
Old 03-08-2009, 03:57 PM
79f2506.6L 79f2506.6L is offline
79f2506.6L is starting off with a positive reputation.
well the 4V heads have big ports,and the 2V heads small ports and these are suited for street use you can bolt a weiand 8010 4 barrel intake to the head if it is on the 351M/400 were the 4V it is not possible cause the intake ports on the head are too big
Old 03-08-2009, 04:47 PM
JBradley500's Avatar
JBradley500 JBradley500 is offline
JBradley500 is starting off with a positive reputation.
yeah the ports dont match at all.. they both have different intakes and headers. 4v's are huge and take either big CI or RPM to get use of them and the exhaust ports aren't that good. the 2v heads are a good overall street or truck head.
Old 03-08-2009, 05:05 PM
i'm bored today so i took a pic of my PME 4v adapter plates that i dont have a use for vs the port on my 1st set of junk 2v aussie heads i have taking up space..
Old 03-08-2009, 06:26 PM
I am also bored,measured mu edelbrock 4v manifold ports,which turned out to be smaller than the ports on the heads-2&1/4 compare to 2&3/8".Maybe my
"2V" heads are 4V??
Old 03-08-2009, 06:42 PM
my edelbrock 4v performer is much smaller than the ports on the heads...ill post a pic. the 2v heads are 2 1/16" from top to bottom and the 4v are 2 7/16".
Old 03-08-2009, 06:48 PM
Old 03-08-2009, 06:52 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
There are no VIN's or serial numbers on Ford mechanical parts.
Numbers matching is a GM thing.
There were no 351M (1975/82) or 400 (1971/82) 4V heads installed on US/Canadian assembled cars/trucks.
The only carb available with these engines was the 2V.
Old 03-08-2009, 06:58 PM
i was going to say the same thing about 2 barrel 400 but i didn't know what engine he has.
Old 03-08-2009, 07:33 PM
Yes,it is a 400.Its a 2V carb,original.Its listed on craigslist,but a guy who's interested said that he was hoping it was a 4V engine,but I guess that's not possible?
Old 03-08-2009, 07:34 PM
not stock 4v...the only way to put 4v heads and intake on is to use the plates like shown in my pics
Old 03-08-2009, 07:40 PM
Which heads do you use for the 4V setup,something aftermarket?
Old 03-08-2009, 07:51 PM
you can get aftermarket 2 v intakes to go with the 2 v heads so you can run a 4 barrel carb.
Old 03-08-2009, 07:54 PM
So,there is no actual 4V head?
Old 03-08-2009, 07:56 PM
Sorry,brainfart there
351c heads on ford 400 Kyle Wood 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-13-2016 10:04 PM
351C Intake Manifolds Ranger92 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 10 05-17-2011 07:30 PM
'66 289 ho intake roger dowty Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 11 05-08-2007 07:53 AM
400 Heads Max RPM??? mudcobra 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 17 02-03-2004 09:38 PM
351C 4V vs. Corvette 350 Knucklebuster Ford vs The Competition 22 07-14-2003 03:22 PM
Tags
2v, 351, 390, 400, 400m, 4v, aussie, bigger, cleveland, difference, engine, ford, heads, pme, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
