Bushing on Gear shifter column - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 03-08-2009, 03:13 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
I was having play on my gear shifter. I previously adjusted the gear select indicator so it would always start in park. Anyway, decided to tear into it a little more. Removed instrument cluster and found play in the the lower bushing on the gear shifter column. Getting up and down play and a little side to side in the gear shifter column at the bushing when I move the shifter slightly. Anyone ever replaced these without taking apart the whole dash more than I already have. I attached a photobucket pic. The bushing is in the center of the pic around the gear shifter column. Also, anyone know if I can start my truck with instrument panel unplugged? Not plan on driving it, just wanted to move it slightly. Thanks for any input, Part numbers would also be great if anyone has them handy.
bushing picture by galexander - Photobucket
Old 03-08-2009, 03:26 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
F250 SD or F350 SD? It makes a difference on the lower bearing.
With or without tilt wheel?
There are upper and lower bearings.
The upper bearing and its retainer (2 pieces) fit top of the column, below the steering wheel, while the lower bearings, bearing retainers are at the bottom of the column.
The lower bearings comes in two sizes.
Old 03-08-2009, 03:29 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
PREMIUM SPONSOR
Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.Riffraff Performance has a spectacular reputation.
Not sure but maybe this will get you closer.
FTEPARTSGUY
1) Gearshift lever 2) Lock switch Overdrive lockout 3) Cap
4) Cap Pin 5) Seal Upper 6) Shift tube
7) Shift tube Clamp 8) Shift tube Bushing 9) Solenoid Interlock
10) Insert Trans position 11) Shaft 12) Selector lever
13) Spring 14) Arm
Old 03-08-2009, 03:53 PM
tdpower's Avatar
re
Quote:
FTEPARTSGUY
Attachment 13738
13) Spring 14) Arm
It looks like number 8. Thanks
Old 03-08-2009, 03:56 PM
That pic doesn't show the upper/lower steering column bearings, retainers, but that's prolly not what the OP wants.
#8 = (2) F3TZ7L278A .. Transmission Shift Selector Bushings (Ed's site calls them Shift Tube Bushings).
MSRP each: $2.99 // FTEpartsguy.com price each: $2.16.
FTE sponsor: FTE Parts Guy = Ed Olson @ PARR FORD in Bremerton WA.
Type the part number into Ed's site to see all the myriad applications.
Old 03-08-2009, 05:26 PM
tdpower's Avatar
I think I need this part: (Ford) F3TZ-7L278-A Bushings
I did start the truck without the instrument cluster and was ok. I guess I will go to ford and see if they have any bushing in stock on Monday.
Old 03-08-2009, 06:33 PM
tdpower's Avatar
Well, I ended up getting a thin plastic bushing and cutting it in half. Put it on top of the existing bushing and no more play in the shifter.
Auto Shifter Woes... Can't get into 1st with New Shift Tube F250_ 1999 - 2003 7.3L Power Stroke Diesel 6 12-12-2016 08:50 PM
Trouble getting truck in gear evil_edwardo 1999 to 2016 Super Duty 5 03-23-2016 12:45 PM
Starting Issue having to put in Neutral oct7brian 1999 to 2016 Super Duty 19 01-13-2015 06:04 PM
Shifter Question 05-X Excursion - King of SUVs 1 02-14-2012 08:15 PM
shifter bushings RIDGWAY66 1961 - 1966 F-100 & Larger F-Series Trucks 3 08-26-2010 09:18 AM
Tags
73l, 99, bushing, bushings, column, f250, f3tz7l278a, ford, gear, indicator, play, powerstroke, shifter, truck, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
