mounting location(s) ?
tanks...
......I promise...last time...what size tanks are you guys using?
...maybe I got a little carried away with the 12-gallon tank?......
...with a rear fuel tank, (forgot in all the excitemnent!)... wonderin' where
I can stash this torpedo......good thing it was an in-stock item...
we discussed this when I purchased it and IF need be I can exchange it
for somethin' else...
Dimensions: 12 1/2" H x 44" L
I just went an remeasured the tank AGAIN and the listed
height does include the mounting legs...they are 2 1/4"
from the tank body...
<O</O
THANKS FELLAS!!!
<O</O
THANKS FELLAS!!!
I have a 5 gal tank it is mounted on the right side, under the cab inside of the running boards( gas tank is on the left side air tank is on the right). My (2) compressers are mounted on the frame crossmember under the back of the cab. My valves are also on the right side behine the tank.
plumbing & mounting...
...well...it looks like I MIGHT have gotten myself in a little bit of a jam...
...look like at 44" overall lenght it's a little too long to fit between the
framerails...unless I get real creative...startin' to get real fun......
...I did find a diagram that helped clear up a few points for me...
..I think...
Do this make sence for just a FB system?...NO hoppin' or dancini'...
Just ride height & layin' frame...
..I think...
Valve Blocks...and Level ManagementSystems...
as I go......and I think it may be a good option for ME...
...thepitshop...which valve block did you go with?
...howz it workin' out?
Chuck...I TRIED to do a search on www.SuicideDoors.com but
kept commimg up empty handed......
...I'll keep at it...I like that idea as my Viair 400C's are oil-less...
Regarding Level ManagementSystems...
...I ran across an advertisement in Classic Trucks for this company
and wondered if anyone as heard of them or has any experience
with their products?
Pricing seems fair...leveling system is ride-height based control only.
Valve block is a-LOT less than Air Ride Technoliges...go figure...
I was gettin' tired of tryin' to get a straight answer out of them...
AccuAir - Air Suspension
...Thanks again...
I have used a 5 Gallon Tank, and valve block all mounted under the rear bed as seen here:
One benefit of having IRS is that the rear Diff does no move, so I have a Prop shaft that stays fixed so was able to make a mounting bracket that went between the frame rails.
There are more pics and details on my site (Link below).
Cheers
Lee
Cheers
Lee
here`s the system i`m running but i have 2 compressors and digital air pressure read out, works slick! a lot less mess than having individual valves!
http://www.ridetech.com/more/instruc...cs/ARC4000.pdf
I'm using a 2.5 gal tank, one compressor, and 1 set of 2 valves (one up, one down) for both rear bags.
the tank is under the passenger side door, the compressor under the bed floor in the right front corner. the valves hung on the cross member where the old parking brake cables went thru.
check valve into the tank from the compressor,
check valve out of the tank into the up control valve.
T to both bags
to the down valve
the difference between the individual valves/block is individual bag control/vs all bags at once.
Sam
T to both bags
to the down valve
Sam
Valves...
Cheers
Lee
Cheers
Lee
...are those "Big Red" valves? How they workin' out? I got to check their "garage sale" section again...
...from time-2-time you can find the ocasional "sweet-deal"......
pitshop...those look like the RidePro valves...right?...how they workin"...
I was hopin' Reno at Accuair would me a good offer on their valve block
AND their e-level managment system...haven't heard back from him yet...
...tick-tock-......
