2006 Lariat Instrument Cluster -> 2004 XL Truck?
Well, since no one knew.. i just tried to install it. It bolted right in with no problems and everything worked ..... Except the biggie... the A/C didn't work.. Now I do not know why the cluster had something to do with this, but the a/c would not engage. Everything else worked.. so I guess i'm stuck with my XL gauges. Anyone know a way around this??
the clusters are a plug n' play for the most part.
you must visit a dealer and have the odometer reset, and to enable the tach and other gauges that the XL cluster did not have.
You can slap a Lariat Cluster in there if you wanted to...just gotta pay the Dealer to enable the different functions the Lariat cluster has over the XL cluster.
not sure why the A/C is messed up...are you sure the XLT cluster is okay...and not messed up?
Actually, everything on the cluster did work. The tach, speedo, temp..etc.. The only thing that didn't really work was the information center, but since the XL doesn't have those sensors such as outside temp and compass I would'nt expect it to work. When I tried to turn my A/C on, it didnt work and so I put it back to stock. I will call a dealer and ask them what they can do.. otherwise its not a big deal
oh, I thought you had an XLT cluster...I should read a bit more clearly I guess
You can buy the sensors and the compass if you want to have the message center work. not to sure if your XL has all the wiring already in place or not though.
does your XL cluster have a TACH already?
normally the Dealership has to enable all the stuff via the vehicles CAN OBD-II system. wierd
06 to 04
On the FX4 the A/C will work.
Walwal44
10-20-2014 03:32 PM
Bluethunder3320
04-06-2014 08:12 AM
