power steering fluid for a 03 escape - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 03-07-2009, 10:11 PM
projectdagger's Avatar
projectdagger projectdagger is offline
projectdagger is starting off with a positive reputation.
i have a 2003 Escape that came with no owner's manual. The power steering fluid is low. I am wondering what type of power steering fluid would it take. i just want to make sure for when i drive down to the local parts house tomorrow.
Thank you for your time.. I hope you can help
Old 03-08-2009, 09:46 AM
Scndsin's Avatar
Scndsin Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
The manual calls for MERCON ATF, which chances are, you won't be able to find. Most here will tell you to just use a name brand ATF that meets MERCON V standards & you should be fine.
Need some help! Jeb81 3.8 & 4.2L V6 0 09-03-2016 09:29 AM
New Escape Steering Column, requires restart to work Heffkids Escape & Escape Hybrid 3 03-06-2016 10:32 AM
power steering fluid or trans. fluid abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-16-2013 05:36 PM
Power steering fluid wicat3 1987 - 1996 F150 & Larger F-Series Trucks 15 09-24-2012 06:20 PM
Possible power steering pump failure? pidaster Escape & Escape Hybrid 3 05-12-2011 10:37 AM
Tags
2001, 2002, 2003, 2004, add, atf, change, escape, fluid, ford, kind, mercon, power, steering, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
