Help Clutch Master Cylinder
So I spent the day replacing the plastic bushing and the clutch pivot bar on the clutch/break peddle. Now that I have it all back together I can't get the clutch master cylinder to make any pressure. Do I need to bleed the air out or something like that???
Thanks
Pat
Thanks
Pat
The clutch is hydraulic the same as the brake master cylinder, so if you have the lines disconnected as you stated then you are subject to having air in the lines, thus needing to be bled to ensure theyre clear.
I had athe same problem with mine when I replaced it. No matter how much I tried to bleed it at the slave it wouldn't.
I ended up bench bleeding the master. Disconnect the metal line from the master and connect a rubber hose to the outlet of the master and run run the other end of the hose back into the reservoir. I used a fitting that was threaded at one end and fit into th emaster, but was loose, wrapped teflon tape around it until it fit snuggly., other end had a hose barb for the rubber hose. Pump it a few times, keep and eye on the leve in the master and when no more bubbles come from the hose, its bled.
You are the MAN! I searched hours trying to find out how to bleed my (non bleed screw slave) 84 E-150, It took about three pumps to go from zero to 95%. I hate smiles so here is a big "Thumbs UP"
