hood repaint - Ford Truck Enthusiasts Forums
hood repaint
Old 03-07-2009, 01:05 PM
NV250 NV250 is offline
NV250 is starting off with a positive reputation.
hood repaint
Hey, the hood on my 250 is fading pretty bad. My question is, since it's just the hood anyone ever just gone to Maico. It's a lifted truck so you can't see the hood to well anyway. Anyone know the cost and how the result would be?
Old 03-07-2009, 02:41 PM
Chaosracing's Avatar
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.Chaosracing is gaining momentum as a positive member of FTE.
Cost really really cheap.....result....paint failure again in about 1 to 2 years.
They do not prep anything right, unless you are willing to pay there outragous fees for that part.
Do yourself a favor, find a reputable body shop in your area and have them do it. Just because other people wont really be able to see it doesnt mean it wont bother you while driving.
Old 03-07-2009, 07:30 PM
joestratton1 joestratton1 is offline
joestratton1 is starting off with a positive reputation.
Pull it off and paint it in your garage, easy cheap and fun!
Old 03-08-2009, 12:18 PM
Really? What type of equipment would I need?
Old 03-08-2009, 12:39 PM
You will need a decent sized air compressor 20 gal is more than enough, spray gun with 1.3mm nozzle. You can hand sand the hood, but you will want sanding blocks for the large flat areas. If you dont use then, you will wind up with low spots in the finish fron your fingers while sanding. Other than that thats about it. But till you buy a spray gun, the paint, clear coat (unless you go single stage), block sander, misc items(such as tape, sand paper, tack rags. You might even need some primer, but that can be bought in rattle cans.
It might just be cheaper to go to a body shop. (It probably will) Now if you are planning on more painting in the future, then it would probably be worth it.
Old 03-08-2009, 11:37 PM
kenseth17 kenseth17 is offline
kenseth17 is gaining momentum as a positive member of FTE.
Quote:
easy, cheap- I wouldn't exactly call this work easy or cheap, if you want good results, allthough not to say it can't be done by someone that has the commitment and dedication, and does their homework before hand to know the products and procedures to follow and gets some practice shooting beforehand. And thier are some decent products, not what I'd call cheap, but that are a little more reasonable then the big name brands.
Fun- sometimes it is, but when something catastraphoic goes wrong, and there are a lot of things that can go wrong painting given the chance, its not too much fun, as well as knowing you just wasted some pricey material. Or wouldn't be too fun if a neighbor ended up complaining, and you have the police at your door and find you painting in a residential area. Not too fun if you don't properly protect yourself (and might not see the effects until the future), and you damage your health.
I'll never discourage someone from trying their own paint work, but lets not mislead them. In this case with just a hood, you might be better off taking it to someone, if you don't already have the equiptment to do it. Maybe you could find someone to shoot it on the side for you reasonably.
Old 03-08-2009, 11:50 PM
Thanks for the help guys. I just got a quote for a strip down and repaint at $500. Does that sound reasonable?
Old 03-08-2009, 11:57 PM
I would get a price from another shop. To me it seems a little high, but then the guy I used to work for didnt like to overcharge his customers either. What color is it BTW, cause that does affect price. ANd since its only faded, I do not see any reason why it needs to be stripped to bare metal. Maybe just sand down to primer coat(if that), reprime then paint.
Old 03-09-2009, 12:39 AM
Quote:
It is black and yeah it is just faded. About 25% of the hood is a bleached white.
Old 03-09-2009, 12:48 AM
I'm willing to bet without seeing the hood its your clear coat thats bad, so then there is definatly no need to go to bare metal. Black is cheap though, its the body work that can kill you with black paint (you probably dont need any) cause black will show every little imperfection.
Old 03-14-2009, 11:40 AM
I found a shop that is gonna do a full repaint for $400. I'm bringing it in Monday. He said it needs to be stripped down and repainted.
Old 03-15-2009, 03:10 PM
frdtruc1 frdtruc1 is offline
frdtruc1 is starting off with a positive reputation.
NV..........If it is just plain old black and nothing exotic.......I think you could get this done a bit cheaper, lole someone said already, black, improperly done, will show every imperfection.
I had my entire truck painted and all the bodywork included for 2000.00 just a few years ago. It was a 3 step? process with a clearcoat and came out just great. Seems like 400.00 for a hood is a bit much, not highway robbery mind you, just a bit high. If you get this done, have them put a quick coat on the underside as well just so it a 100% match.
Old 03-16-2009, 11:35 PM
What do you guys think of painting the truck flat black? Anyone tried that?
'78 F250 factory hood bracing? 71LTD390 1973 - 1979 F-100 & Larger F-Series Trucks 34 03-17-2015 10:15 PM
95 f 250 hood wont open fordinmudd 1987 - 1996 F150 & Larger F-Series Trucks 5 03-26-2011 05:25 AM
Cutting hood for a hood scoop?? bkohne1 1973 - 1979 F-100 & Larger F-Series Trucks 20 12-14-2010 02:18 AM
Anyone running a cowl hood from cervini's kystangbanger 1999 to 2016 Super Duty 5 02-06-2010 01:41 PM
Cowl Hood For 89 F250 armyboy 1987 - 1996 F150 & Larger F-Series Trucks 2 07-15-2007 11:20 PM
Tags
1992, buy, cheaper, classic, cost, door, f150, f250, ford, hood, metallic, paint, painting, price, repaint, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
