Smelling gas
Old 03-07-2009, 09:56 AM
Pappys53's Avatar
Pappys53
Pappys53 is offline
Smelling gas
Whenever I fill my 53 up, I smell gas until it I driven it for a while. Could this be that the seal on top of the tank for the sending unit needs replaced? The PO put carpet in but did not cut out the inspection plate for the gas tank like they did for the master cylinder. I need to cut that out, but thought I'd ask here to know what to look for.
Old 03-07-2009, 11:02 AM
Fomoko1's Avatar
Fomoko1
Fomoko1 is offline
Received 1,340 Likes on 1,102 Posts
It could be the gasket under the sending unit or a split in the rubber hose connecting the filler tube to the gas tank.
Old 03-07-2009, 02:46 PM
Stephen67's Avatar
Stephen67
Stephen67 is offline
By any chance are you eating a chilli-cheese dog while waiting?
sorry, I couldn't resist.
Old 03-08-2009, 08:21 AM
Last Chance 56's Avatar
Last Chance 56
Last Chance 56 is offline
Sounds like the sending unit or the knuter valve attached to the sky hooks.
Old 03-08-2009, 10:23 AM
Pappys53's Avatar
Pappys53
Pappys53 is offline
I found the hose where it connects to the tank was leaking. But I think the gasket on the sending unit is leaking some also. I will see how strong the smell is when I fill up again. Thanks for the replies. Thanks Stephen67 for the laugh. I need all I can get right now. I will probably be informed this coming Friday that my last day with SPRINT will be March 27.
Old 03-08-2009, 12:11 PM
49fordpickumup's Avatar
49fordpickumup
49fordpickumup is offline
Leak
Since you need to remove the filler tube to replace the rubber joint, you may want to consider welding a vent tube in the filler tube (top side)and running it down and out under and aft of the cab. Doing this, you can install a non-vent fuel cap. The rubber around the fuel cap between the tube and cab as it ages will cause fuel smell to enter cab sometimes.
Other topic: I retired from Sprint a few years ago. Working there is like a Boeing contract, up/down/up/down. Nextel was not a good merger. I wish you well. chuck
Old 03-09-2009, 10:15 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Originally Posted by 49fordpickumup
Since you need to remove the filler tube to replace the rubber joint, you may want to consider welding a vent tube in the filler tube (top side)and running it down and out under and aft of the cab. Doing this, you can install a non-vent fuel cap. The rubber around the fuel cap between the tube and cab as it ages will cause fuel smell to enter cab sometimes. chuck
The vent tube and non-vented cap works really well. I did this on my 48 and I never smell gas fumes...
