Reart disc brake conversion?
on
All the info you should need is linked here
https://www.ford-trucks.com/forums/6...-are-here.html
http://www.fordmann.com/F350.rear_disc_brakes.htm It is not as much work and expense as the guy in the write up makes it. I have done it and it was very easy and looks OEM. He purchased every thing from a wrecking yard, then replaced almost everything. I got my items from a used rear at the Drive Line place here and everything was in good condition.
denny7170
10-19-2016 01:05 PM
moose79
03-26-2016 09:07 PM
fordxxx
12-26-2005 08:42 PM
