1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Replacing ball joints on 2002 F250
Old 03-07-2009, 07:51 AM
Corey M's Avatar
Corey M
Corey M is offline
I'm trying to find out what you need to do to replace the upper and lower ball joints on ford f250 2002. Not sure what I need to do to get the housing that the ball joints are pressed into off the axle. I have it to that point and have that housing loose however the 4 wheel drive shaft is in the way. Any help would be great Thanks
Old 03-07-2009, 09:11 AM
Pocket's Avatar
Pocket
Pocket is offline
Old 03-07-2009, 10:21 AM
ironmine's Avatar
ironmine
ironmine is offline
The axle shaft slides right out.
Read this, from our very own RacerGuy, from this forum's tech folder ... https://www.ford-trucks.com/forums/3...ll-joints.html
Good luck
bigcountry1009
06-19-2014 03:28 PM
rkeith213
10-12-2013 08:38 PM
2002 F350V10
03-11-2010 09:08 AM
cbradford
10-20-2008 07:46 PM
kcbillo1
11-14-2006 08:48 PM
Quick Reply: Replacing ball joints on 2002 F250
