heated mirror not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-06-2009, 11:11 PM
getnbz getnbz is offline
getnbz is starting off with a positive reputation.
is there anyway to replace the heating element in the mirror i hought it was a ground problem but signals and lights work and controls too really sucked ice on drivers side and passenger side is clear
Old 03-07-2009, 01:23 AM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
The heating element is added to the back of the mirrors, so you could replace the mirror with a new one that would have it on. I think you might have a different problem though. It is quite rare for the element to go on them. I would check the wires and all connections starting from the mirror. Or pop the switch, and the connection at the mirror and see if you have continuity thru the power lead. And then check to the mirror end from the plug. (You could have a frayed wire somewhere or the connections just loosened off)
Old 03-07-2009, 06:38 AM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
The power for the heater doesn't come from the switch, but a 99 shouldn't have Heated T/S mirrors anyway, so they must be added.
Old 03-07-2009, 07:11 AM
thats correct i did add them
Old 03-07-2009, 10:13 AM
JockD's Avatar
JockD JockD is offline
JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.JockD has a very good reputation on FTE.
Check for voltage at the mirror before you give up on the heating element. Did you use later stock mirrors or aftermarket ones?
Old 03-07-2009, 11:01 AM
aftermarket
heated mirrors ? Leef250 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-08-2015 03:26 AM
Electrical problem fp_5 2004 - 2008 F150 1 03-02-2015 04:42 PM
Side Mirror Pin Diagram Gene Horr Excursion - King of SUVs 4 11-16-2013 09:29 PM
2004 Heated Side Mirrors With Directionals On 2001 robjs111 1999 - 2003 7.3L Power Stroke Diesel 5 10-27-2009 02:51 PM
Aftermarket tow mirrors for 2008+ the Goat 1999 to 2016 Super Duty 10 09-15-2009 01:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
