Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-06-2009, 11:20 PM
bunklash's Avatar
bunklash bunklash is offline
bunklash is starting off with a positive reputation.
Tall tale?
Talking with a 30+ year school bus mechanic the other day. He told me that the 7.3 is an International engine that Ford made some mods to. He claims the #7 injector is different than the others as a noise reduction method, and that the 7.3's in his school buses have an extra 60 HP because they don't have the one different injector. Is he full of it, or is there some truth to it?
  #2 (permalink)
Old 03-06-2009, 11:30 PM
eckart's Avatar
eckart eckart is offline
eckart is starting off with a positive reputation.
I believe its the # 8 injector but the hp thing is bs.
__________________
1999 F350 sd sb/sc 4X4 6spd PSD
  #3 (permalink)
Old 03-06-2009, 11:32 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Be Thankful...
2002 Ford F-350
Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all Ponyboychris is a name known to all
One different injector = 60HP???? Wow, there's a mod we can use.
OK just messin' with ya!!!!
I think your buddy is pulling your leg.
__________________
Chris
2002 F350 XLT, 7.3L CC 4x4, LWB, SRW, Autometer Ultralites, DP TUNER, BTS Trans, 6.0 tranny cooler, AIS w/zoodad, Warn Hubs, 4" MBRP exhaust, '08 rear end cover, Foil Delete, Heated Tow Mirrors, AIH Delete, Homemade CCV mod., Bilsteins.
The Silver Bullitt PAA# 24
  #4 (permalink)
Old 03-06-2009, 11:36 PM
IDPisan's Avatar
IDPisan IDPisan is offline
IDPisan is gaining momentum as a positive member of FTE. IDPisan is gaining momentum as a positive member of FTE.
The engine is made by international it is the #8 injector that is different. If the school buses had an extra 60hp everyone on FTE would be riding the short bus .
__________________
My two cents, Jeff
Early 99 F350 4X4 CC DRW 6spd. 6637, MKO 4" turbo back 5" straight piped exhaust 6" tip, ISSPro Gauges, Pyro, Boost, Water temp, DP Tuner Stock, 40tow, 60tow,80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator, Auto Enginuity, GPR LED Indicator. 6.0 intercooler, CCV mod, EBPV delete,Wastegate Mod. 320,000 miles and counting.
  #5 (permalink)
Old 03-06-2009, 11:40 PM
bunklash's Avatar
Well at least he knew a little of what he was saying. I loved the short bus comment, good one!
  #6 (permalink)
Old 03-06-2009, 11:41 PM
Be Thankful...
2002 Ford F-350
Oh yes, the 7.3 it is an IH engine and the mods that are performed on it by Ford include mostly emission requirements and a few noise reduction additions. I'm sure someone can chime in with a better breakdown of more differences.
__________________
Chris
  #7 (permalink)
Old 03-06-2009, 11:44 PM
eckart's Avatar
If you loose 60 hp in one hole from a different injector he is saying you have atleast 60 hp per hole. The 480 hp for all 8 holes. Can I get one
__________________
  #8 (permalink)
Old 03-07-2009, 03:22 AM
triskit16's Avatar
triskit16 triskit16 is offline
2000 Ford F-250
triskit16 has a very good reputation on FTE. triskit16 has a very good reputation on FTE. triskit16 has a very good reputation on FTE.
Awesome...I always wondered where they got these new injectors from. If I wouldve known this a few years ago I couldve gotten yall tons of bus injectors! lol They would sell at a premium. 60hp my azz
__________________
-Tristan
2000 F-250 XLT 4x4 Ext Cab SB Auto DP Tuner 60T 80E 120R 4" Turbo Back WW F650 Dash DiPricols MAC Intake Foil Delete CCV Firestone Bags LED...
  #9 (permalink)
Old 03-07-2009, 04:12 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of
the IH school bus and there medium duty trucks have what IH calls a high torque T444E (7.3) in them..they use a differnt injector all together..they also run a bigger non waste gated turbo...thats why they have higher HP and TQ..ford made there changes to the T444E and called it the 7.3 power stoke..
AC injectors are found in the high torque version of the T444E and do not come in any Powerstrokes. They have the same internals as the AB injectors with the exception of the single shot plunger and barrel. However due to them being single shot injectors they flow 160cc. This is due to the way the split shots work. They have a small passage that opens, much like a port in a two stroke engine, that are uncovered that bypass the injection pressure out the side of the barrel instead of out the end through the nozzle. Because of this pause a portion of the travel of the plunger does nothing for injecting fuel so a split shot injects less fuel for the same amount of travel as a single shot.
__________________
Early 99 7.3 F350 auto,GTP38R BB turbo, AFE stage2, 5" strait pipe, DP live tuned-PMT1 soon to happen, 140 IDM, Terminator Modified 17* HPOP , DIY fuel bowl delete, DI Regulated Return fuel feeding Ryan Casserly's SS stage 2's moded EPD process 100% over nozzles http://fullforcediesel.com/
exploded view of a 7,3 << more pix of my truck
  #10 (permalink)
Old 03-07-2009, 04:40 AM
greedy737 greedy737 is offline
greedy737 has a good reputation on FTE. greedy737 has a good reputation on FTE. greedy737 has a good reputation on FTE.
So the guy is right in a way? Has anybody gone this route?
__________________
RONNIE
2001 F250 4x4 Turboback 3.5" straight pipe side exit, Superchips, Zoodad, 6637, WW, Bellowed Up Pipes http://www.powerstroke.org/forum/ima.../drinking4.gif
PAA Member# 42
  #11 (permalink)
Old 03-07-2009, 04:45 AM
Quote:
a lot of us have..thats what single shot injectors are..click on the full force link in my sig...i have the stage 2's ..160cc with moded nozzles....some guy's run the non waste gated van turbo...but to run SS injectors you need custom tuning..
__________________
  #12 (permalink)
Old 03-07-2009, 07:51 AM
spdmpo's Avatar
spdmpo spdmpo is offline
2000 Ford F-350
spdmpo has a good reputation on FTE. spdmpo has a good reputation on FTE.
Curious, why would Ford want to use the split shots over the single shots then?
__________________
Keith
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
'00 F350 CC LB 4x4 PSD - DP Live Tuning, ATS housing, 6.0 IC, Ford AIS, 4" Magnaflow, BD X-Monitor, Front leveling kit, Firestone air bags, JWVB, FRx, HPX, coolant filter, Hutch mod, ITP in-tank, Carter lift pump, CCV, Tru-cool, AIH delete, OBA, cold a/c
  #13 (permalink)
Old 03-07-2009, 09:23 AM
Izzy351's Avatar
Izzy351 Izzy351 is online now
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
Supposedly a "cleaner burn". A pilot shot is injected which gets the combustion started, then the rest of the fuel follows in the way Ron described. I would rather have more power & better mileage over a "cleaner burn", but that's what the tree huggin' fruits of the world have done for us.
__________________
  #14 (permalink)
Old 03-07-2009, 09:38 AM
sneak sneak is offline
Youngster
sneak is starting off with a positive reputation.
The SS's use what is called pilot injection to meet specific emissions standards, and I believe they are a bit quieter.
EDIT: Beat to the punch
__________________
[font=Book Antiqua]Paul
2002 F-350 Powerstroke - Kwik(6637), removed the muffler, Stancor GPR, DB Electrical high torque MONSTER starter
Three other FORD trucks, a Willis JEEP, and a 5-TON Diamond-T truck
Quote:
Originally Posted by 4EXTRDR View Post
I'm about 3 hours away from owning an 06' Duramax truck...
Quote:
Originally Posted by riverrat41 View Post
You'll be back,you cannot quit Strokin'...
  #15 (permalink)
Old 03-07-2009, 09:51 AM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
There were changes and updates to the T444E International engine over the years. We have 7 of them from 1996 to 2001 in school buses, ours are 190 to 210 horsepower.
International also went to split shot injectors in the later 90s and our 2001 has a wastegated turbo
__________________
2004 E-450 6.0 139,000 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
