Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-05-2009, 07:24 PM
427 fordman 427 fordman is offline
427 fordman is gaining momentum as a positive member of FTE.
complete body swap 71 on highboy chassis
Hey guys. I am new to this site usually on the 73-79. Anyway I have a 76 highboy with a completely junk body. It is straight but rusted out bad. I also have a 71 f100 ranger 2wd body that is pretty straight and very solid. Hardly any rust anywhere. I would like to put it on the highboy chassis and was wondering if anyone knows if my body mounts will line up or if there are any other challenges I will run into. Both have gas tanks behind the seat. I know the frame is narrower in the back of the highboy than the 71 and will have to deal with that for my box. Any help or just friendly info would be great. Thanks
__________________
Darin I BLEED BLUE
1976 F250 hboy w/71box 390 "Ol'brown"
1997 F250 HD 7.3 10k 3-4" downpipe w/straightpipe 6637 intake ebpv gone
1966 Ford Fairlane drag car 514cu.
  #2 (permalink)
Old 03-05-2009, 07:54 PM
Redcat Diesel's Avatar
Redcat Diesel Redcat Diesel is offline
1972 Ford F-100
Redcat Diesel is gaining momentum as a positive member of FTE.
Darin this topic comes up about every other month. The cab and front clip are a bolt on. The mounts are in the same places and the bolts drop in. The only thing you may run into is a minor one with the rear cab mounts. Some highboys I've seen had the rear cab mounts on the outside of the frame rails like F350's used. Your 71 rear mounts are inside the frame rails on the rear cab crossmember. It's no big deal since all of the cab floors were stamped for both types of mounts. All you have to do is drill 2 new holes. The bed takes a bit of juggling since the wheelbase on the highboy is 2" longer than the 71. If you set the bed back a little farther than normal the wheelwells will align with the rear tires.
__________________
Clay
96 F150, 72 F100, 67 F100
Pennsylvania chapter member
" Don't the girls all get prettier at closing time" - Mickey Gilley
  #3 (permalink)
Old 03-05-2009, 09:23 PM
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.
That is going to be soooo cool. :)
Alvin in AZ
  #4 (permalink)
Old 03-06-2009, 07:35 PM
colt4x4 colt4x4 is offline
colt4x4 is starting off with a positive reputation.
doing the same thing
I have a 69 2wd F250 I am swapping on a 76 hiboy chassis as well. As far as I have been able to research, the hiboys until 77.5 have a 34 inch wide frame all the way down, no widening out on the 4wd frames. 2wd do widen out in 73 I believe. The springs mount on hangars outside the frame. The rear cab mounts are outside on the 76 frame. I am hoping my 69 power steering box will work as well, replacing the assist on the 76. The wheelbase diff of 131 vs 133 is a concern. I have seen one local here with the bed just put on up to the cab so the rear axle is offset 2 inch back in the wheel well. Noticeable to the Ford guys for sure. If you move the spring mounts, you also have to move the overload mounts and the shock mounts on the frame all forward too. I might just section the frame instead. Should be great fun! Best of luck on your project.
  #5 (permalink)
Old 03-07-2009, 08:17 AM
wizzard351's Avatar
wizzard351 wizzard351 is offline
lost in the 70's
wizzard351 has a great reputation on FTE. wizzard351 has a great reputation on FTE. wizzard351 has a great reputation on FTE. wizzard351 has a great reputation on FTE.
ya itll work
one day job!!
__________________
71 F250 460 4sp w/pto 4x4
92 F150 302 auto 4x4
96 F250HD 460 4x4
01 ranger 4.0 4x4 (wifes)
  #6 (permalink)
Old 03-07-2009, 09:26 AM
Thanks for the pics wizzard. Looks excellent!!!
__________________
Darin I BLEED BLUE
  #7 (permalink)
Old 03-07-2009, 02:14 PM
1969F2504X4 1969F2504X4 is offline
1969F2504X4 is starting off with a positive reputation.
I did it to my 69 years ago. 69 F250 body on a 77 frame. I fudged the bed forward 1 inch so the gap wasn't as bad between the cab and bed. The rear axle was off in he wheel wells also. It drove me nuts for 13 years. Last year I blew it all back apart and put it on a 70 F250 frame.
  #8 (permalink)
Old 03-07-2009, 03:43 PM
wizzard351's Avatar
lost in the 70's
ya on the last pic the bed wasnt all the way up after i took the pic and noticed it and slid it forward,i was tryin to get all the pics before it got dark
__________________
96 F250HD 460 4x4
  #9 (permalink)
Old 07-04-2009, 05:11 PM
tbadd tbadd is offline
tbadd is starting off with a positive reputation.
69 f1oo ranger to newer chassis?
Thanks for the info. I've been searching all day for frame specs. Up to what year are the frames relatively interchaneable? I was wondering about a 1990 chassis under a 69 body? I can't find any sites with measurements or specs for this type of project. Any help is greatly appreciated.
  #10 (permalink)
Old 07-04-2009, 05:32 PM
jowilker's Avatar
jowilker jowilker is online now
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
tbadd, It wont be bolt up but I bet it can be adapted without too much fussing. I suspect you may have to cut and move some mount points, and the chassis will be longer. I looked under one sometime in the 90s and was amazed that the similarities in the mounting system.
Bet you can pull it off.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #11 (permalink)
Old 07-15-2009, 02:32 AM
71hightoy's Avatar
71hightoy 71hightoy is offline
71hightoy is starting off with a positive reputation.
Ive done many of these swaps over the years as well.. as far as re drilling the rear cab mounts .. i went ahead and purchased some rubber plugs to cover the stock holes that i no longer needed and 2 more to make the new drilled holes look more stock.. that was it.. im building a another one as wee speak 1971 2wd body on a 1972 4x4 frame.. no problems mounting the body.. all bolt up except the bed . buddy of mine has went through (2) 2wd 1977 bodies on his 1976 4x4 frame. allways turns out good .. wish you luck with the build
__________________
1971 ford F250 highboy. big lifted son of a gun!
1964 Buick Riviera. 425 c.i. sleeper
WHEELINN FOR LIFE!!!
Tags
1966 , 4x4 , 69 , 90 , bodies , body , cab , car , chassis , f100 , ford , highboy , measurements , mount , put , swap , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
