I ordered a poly bushing kit for my front swaybar, got the axle mounted bushings in, but I cant fully remove the passenger swaybar link!
The top bolt & washer come in contact with the tranny bellhousing. Does that silver washer separate from the bolt head? Mine did not want to come undone...
I need a press to do sway bar bushings!?!?! Wow guess I'll have some fun tomorrow with my vise...thanks again!
I kno Right!!! a while back I replaced the leaf spring bushings. all's I used was the vice and a air compressor with the chipping hammer, if ya get a good area it will slowly push it right outta there.
NEED HELP!!! i can't remenber which way the links go back on the truck...is the "wide" end on the bottom connected to the sway bar or is the skinnier end?
Your telling me...
All is well, i just used a torch to heat the links in my other vise to get them out. The ride is AWSOME! Big difference. Thanks again!
take a minute when your done riding around enjoying quiet ride and give some rep points to author i just did mine 2weeks ago that article helped mine go smooth also
Quick ? for u guys that just did your bushings. I'm planning on doing mine in a week or so. Once the old ones are pressed out..do the new poly ones need to be pressed back in?
Not exactly "pressed". They can be tapped back in w/ a hammer. In the kit there are metal sleaves that slide through the holes in the bushings. The top bolt on each link will need to be hammered in with force into these bushings, just dont forget the big washer in between.
Thanks a bunch guys! I'm always glad to hear about someone fixing their clunk by replacing the sway bar bushings instead of the ball joints or something more severe!
