Crane 444232 Cam - Ford Truck Enthusiasts Forums
Crane 444232 Cam
Old 03-05-2009, 01:41 PM
BRay09's Avatar
BRay09 BRay09 is offline
BRay09 is gaining momentum as a positive member of FTE.
Crane 444232 Cam
I was looking at buying a new cam and headers for this summers build. The question i have is: Is there a cam that will give me more power from a SD system without sacrificing much reliability of this motor?
I still want the powerband to be from idle to 4000 or 1500 to 5000. I have never gotten anything higher out of her now, maybe 4300 in second gear with a C6 trans.
Vehicle:
1989 F250 Reg cab
351w w/c6
35000 orig miles
4x4
Old 03-05-2009, 02:00 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
I have looked and have not found a cam that models significantly better, given the restrictions of SD.
Old 03-05-2009, 02:05 PM
straightsixer straightsixer is offline
straightsixer is starting off with a positive reputation.
I'd be alittle nervous buying anything that was made by Crane seeing how I heard they were out of business, just incase you needed tech support.
Old 03-05-2009, 07:46 PM
BRay09's Avatar
Quote:
Why would I need tech support?? I got for that!!
Old 03-05-2009, 09:15 PM
paintslinga2010 paintslinga2010 is offline
paintslinga2010 is starting off with a positive reputation.
I put one in my truck and havent looked back since. I would go for it even with crane in the state they are in. Just make sure everything looks good before you put it in, not a whole lot can go on. I havent noticed any problems since installation and my truck if anything is more reliable because i re-did some stuff while i was putting it in( hoses, injectors, timing chain, leaky gaskets.
lmk if you have any other questions or just search cam swap thread
Old 03-05-2009, 09:29 PM
BRay09's Avatar
I have to change the head gaskets while the motors out. May throw in some 1.7 RR while im in there. May be adding a high flow oil pump and a new pan also. Im probably going to fix the thermactor system for the back of the heads too. or take out all the emissions stuff, im not sure yet. There's no cat, and the tubes on the back of the heads are plugged, so ill probably just take out the remaining peices.
Old 03-08-2009, 09:38 PM
bigblack302 bigblack302 is offline
bigblack302 is starting off with a positive reputation.
I wouldn't go with that cam if I were you. In my opinion, it's too agressive for the SD system with it's 1/2" lift and tight lsa.
I had experience with crane cams on FI systems before and I found them not to be FI compatible even though they said.
I would stick with the comp cams. It's a milder cam and I believe it will work well with the SD system. Remember, these SD systems need a lot of vac at low rpm in order for proper fuel calibration. something I don't think you're gonna get with crane. It can cause you to throw a cel, engine damage, and/or eat your cat.
better to play it safe in my opinion
Old 03-08-2009, 11:56 PM
Conanski's Avatar
Quote:
You must be looking at the wrong spec sheet, the Crane 444232 is very computer friendly.
Crane Cams 444232 - Crane CompuCam Cam and Lifter Kits - summitracing.com
Old 03-09-2009, 01:15 PM
bad info on my part, apologies....
Old 04-22-2013, 03:32 PM
Salts's Avatar
Salts Salts is offline
Salts is gaining momentum as a positive member of FTE.
im thinking about putting one in my 97 5.8 ..its just a simple install right? I don't have to mess with electronics or anything its just mechanical?
Old 04-22-2013, 03:33 PM
Salts's Avatar
also what was the gain from the install?
Old 04-22-2013, 04:43 PM
Conanski's Avatar
Salts you get the ThreadMiner award for today with this oldie from 2009!
Your '97 motor already has a decent roller cam in it so a flat tappet is considered a step backwords. Instead bolt on some 1.7 rockers and longtube headers for a solid boost across the board.
Old 04-22-2013, 05:09 PM
BRay09's Avatar
Ahhh, I remember this thread. Learned A LOT since then. But I agree with Conanski.
Old 04-22-2013, 05:48 PM
Salts's Avatar
question what does SD standfor and what is MAF which is the other set up...im a decent mechanic but i don't know anything about most of the language used..
Old 04-23-2013, 10:40 AM
Conanski's Avatar
SD = Speed Density. The EFI system depends on a strong and steady manifold vacuum signal and pre-programmed tables to manage fuel and ignition.
MAF = Mass Air Flow. The EFI system utilizes a sensor to measure incoming air mass(volume) and uses that and pre-programmed tables to manage fuel and ignition.
MAF is the superior system because the computer has real time input on airflow through the motor so it can better adapt to environmental conditions and modifications without any additional programming.
Block selection - Building a 351W Aaron-71 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 14 10-09-2015 08:13 PM
pull motor, remove front clip, or just work in truck RockWVU Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 07-19-2012 08:11 PM
Replace C6 W/ C4 or AOD? 4x4Expedition 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-11-2011 02:11 PM
302 with Comp Cam idle RPM hooler1 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-14-2011 08:25 PM
Engine swap for 85 Bronco rikfish 1978 - 1996 Big Bronco 12 06-11-2002 08:41 AM
Tags
444232, 50, 58, cam, cams, camshaft, crane, early, f150, flathead, ford, review, specs, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
